diyAudio.com diyAudio Forums Archive > Top > Source > Digital
NAD Cd Player 510 - Click HERE for Original Thread
xicomos
Hi all,
My NAD Cd Player 510 stop working.
When I insert a CD only "No Disk" is present. I can't heard any spinin od the CD.
Does anyone have the service manual of this cd player or knows how to repair this problem.
Thank you in advance.
Xicomos
helios999
if cd turns , it is surely the head laser , else looks for a switch for good position
what laser is ?
:D
xicomos
The problem is it doesn´t start to spin. Imediately afer I close the cd tray, it apears the "no disc" message. Can be a motor drive problem ?
Hugh M
I too have a 510 with the same symptom.
A friend of mine saved it from certian death curbside.
In great shape tho.
I replaced the laser assy (a sony kss model) and that didn't help.
I am also in need of the service manual if anybody has one to share or sell. Its been on the shelf now for a year or so cause I have a couple of other cdps but I would like to fix it and do some tweeking on it.
Hugh
luxe
you can buy a service manual from vintageaudiomanuals.com ,
don't know the price ,depend where you live.
maybe you could help me ,a friend of mine has 2 burns resitor in is 510 that are to damage to read, could you check and tell me there value.There are R110 and R114.
hope my info will help and that you can help
luxe
gguertin145
I had the same problem it was a bad laser and was 200 bucks to fix it may have been a different model but it was a nad cd player it was about 5 yrs back though so??
luxe
The original laser assy for the 510 is a Phillips cdm12.1 ,you can replace it with the Phillips vam 1202 , easy to find on the internet and not expensive.
luxe
xicomos
Hi all,
Sorry for the delay.
The value for R114 is 10k Ohm with 5% tolerance.
The value for R110 is 1 Ohm with 0.1% tolerance.
I hope this help.
Xicomos
luxe
thank you for the info and hope the one about the service manual and laser assy will help you as well.
Luxe
guicarle
do you think it could be possible to also look for the R111 for me. I think I might have burned it trying to fix the new laser. Thanks a lot!
Page generated in 0.025511980056763 seconds with 16 queries,
spending 0.00682783 doing MySQL queries and 0.01868415 doing PHP things.
Please support our sponsor.
