diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
mounting plate for transformer - Click HERE for Original Thread
dine1967
I have a couple of toroidal transformer which do not have any mounting plates. where can I source them locally...ie home depot or lowes etc. any pointers would be helpfull.
thanks,
Dinesh
richie00boy
You need the big rubber washer/donut as well.
dine1967
Iam looking for the metal donut. The rubber washer won't be a problem.
AndrewT
It does not have to be metal.
It should retain its shape if it gets warm and preferably fire resistant.
It might help cooling being a conductor.
I have seen a number that have a plastic infill with a bolt through that, cooling here is obviously not an issue.
richie00boy
Yes, in the absence of the DIYer getting hold of potting compound, you might be able to fill the centre with epoxy. You would need a pillar drill though and possibly a milling attachment unless you can be sure your top surface will be true.
chipco3434
I just built a dual mono amp with a couple of the cheap PE toroids. I mounted the toroids on a plexiglass rod. I drilled the plexi rods to accept an led. They light up when the amp is on.
You can epoxy the rods to the chassis floor.
Page generated in 0.019167900085449 seconds with 16 queries,
spending 0.00789523 doing MySQL queries and 0.01127267 doing PHP things.
Please support our sponsor.
