diyAudio.com diyAudio Forums Archive > Top > Market Place > Trading Post
Wtb 24/192 Dac - Click HERE for Original Thread
rmihai
I am looking for a 24/192 able DAC. Can be a DIY completed project (including chassiss and all the rest) or a commerical DAC.
I would prefer to have a DAC per channel.
transducer
I've got an Analog Devices AD1896 DAC that I'm not using. It is 24/192 capable, it uses the Crystal CS8414 receiver, an Analog Devices AD1896 upsampler, and an Analog Devices AD1852 DAC. It is an evaluation board, very well designed. You would have to add a +/-15V power supply and a case to it (I could help you out with that if you need help). It's a pretty cool unit, you can experiment with upsampling to various bit rates and frequencies, it even has a digital output, so you can use it as an upsampler with another DAC. Because of the upsampler (the AD1869) it should be very immune to jitter (everything gets reclocked).
I bought it but went to a different type of system (6 channel digital crossover) so I'm not using it. I'm also in Toronto, let me know if you are interested. It wasn't cheap though.
rmihai
I've got one. Thank you
transducer
Do you mean you have an AD1869 evaluation board?
rmihai
Oh no - a different DAC I meant.
transducer
Oh, Okay. I found the receipt for mine, I paid $310CDN for it, if you're intereted in mine I'd want $250CDN.
Good luck with your dac.
Page generated in 0.021801948547363 seconds with 16 queries,
spending 0.00893927 doing MySQL queries and 0.01286268 doing PHP things.
