diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Transformer deal??? - Click HERE for Original Thread
gcnewbie
I can get some AVEL transformers that don't exactly match the recommendations I've read on this board and elsewhere, but still wanted to get people's opinions on whether either was suitable in an LM3875 based amp?
Option 1 is 150Va, 2x28.4V, 2.67A
Option 2 is 100Va, 2x25V, 2.00A
Any opinions as to their suitability?
Nuuk
25 VAC is the maximum that you can use with the LM3875 unless you are regulating the supply and dropping the voltage. :att'n:
100VA is a bit low for two channels but it depends how much power you need, ie what speakers you are using with the GC. One transformer per channel would be better.
gcnewbie
Is there a recommended amperage range as well?
grege
Hi gcnewbie,
100Va = 2x25V x 2.00A
Hope this answers your question. ;)
Page generated in 0.019747972488403 seconds with 16 queries,
spending 0.00816298 doing MySQL queries and 0.01158500 doing PHP things.
Please support our sponsor.
