| halvardf |
| I am planing to build an amplifier using the STK4050V chip, but since I don't know how to design a PCB, I was woundering if anybody would be so kind and share a PDF or something with the PCB layout so I can etch it myself... |
| e96mlo |
Check out the data sheet for the STK4048XI. It has a layout that you perhaps can use. The drawback is that it is shown in a component/tracks view so you will have to change it somehow.
If that doesn't work then maybe you can use it as a guide when making your own layout.
/Marcus |
| e96mlo |
I couldn't reach your site. Maybe it's down for the moment?
/Marcus |
