diyAudio.com diyAudio Forums Archive > Top > Source > Digital
DCX2496 update problem - Click HERE for Original Thread
heineb
Hi everybody,
Tonight I did the most worst thing ever - I wanted to update my dcx2496 with new firmware, but it stalled in the middle of the transfer and now it won't get pass the startup message. I can't see it anymore on the setup software. Does anybody have a solution to this problem ?
Best regards
Heine
mac
Try this: http://www.dvd-software.info/forums/ftopic22245.html
Davey
Mac,
That link doesn't seem to work for me.
Heine,
Hold down the leftmost button and turn the unit on. Then try your update procedure again. It should work.
Davey.
heineb
Thanks for the advice - the left button and power on seemed to power the unit up in upgrade mode. But I still have a general problem in transfer software to the unit - it detects it fine, but once I start to transfer presets or upgrade sofftware it says the connection was lost and it had stopped to transfer the file. I've tried two different computers but the result is the same. Any of you who have had this problem before ?
.Heine
Davey
Heine,
The process is a bit funny. I've had it hiccup on me before. Once you've clicked the "software update service" button and selected the proper file does it start uploading and proceed for awhile before quitting?
Try using a previous version of the GUI and firmware file to see if that works. Also a different cable.
Hope that helps.
Davey.
weissi
Hello!
sorry for beeing a little bit o.t.
Anyone can tell me wich Converters the DCX uses?
Would a DCX be a better solution than a DSP8024 + active 2way X-over in terms of flexibility and features?
thanks a lot
tiroth
I think we're talking apples and oranges -- the DSP8024 is REALLY old now! Clearly DCX is more flexible and has more features.
If you asked about DEQ2496 and active xovers, it becomes more questionable. The DEQ has a lot of processing power for EQs compared to the DCX.
heineb
Hi Davey,
The DCX acts just as you describe - I'll try what you suggest and get back.
Thanks,
Best regards
Heine
weissi
asked īcause I got a DSP8024 for 120Euros on Ebay... yes, itīs old, I know ;-) So maybe I resell it, hoping to loose no money....
Problem is that I need a 2-way XO... Does the DEQ2496 feature a XO? couldnīt find the info right know... otherwise the DCX would be the way to go for me, coming from a EMU0404 and going to GCīs.
Thanks for your answers
audio-kraut
no, it does not feature an xo, its "just" a dsp.
TNT
quote:
ehh - I think the XO in the DCX is implemented in DSP actually ...
did you mean: .... just an *EQ*?
audio-kraut
No, the deq ist a lot more than just an eq - so i called it a dsp - digital sound processor. It can upsample to 24/96, contains a fbdestroyer, can change the width of the sounstage, has dynamic eq's etc.
Question - is DSP a process or a machine or both?
weissi
DSP or digital signal processing is - a mostly mathematical process... you know, all that has to do with Fourier calculations.
To the XO: simple question: is it possible to split one input into a high and low output?
audio-kraut
The DCX can split into two and three channels. The slopes, x over points and the mode (linkwitz reily, butterworth etc) can also be selected.
According to you slope some filter power may be left for equalizer function. Most important from my experience ist the possibility of time delay correction and phase - esp. when you run a subwoofer that wants to be integrated with satellites.
weissi
Ok, thanks! What I see now is that the DCX helps me more than the DEQ... Have you modded your DCX?
audio-kraut
no, it's stock and likely will stay that way.
The only upgrade I think it deserves are better xlr connectors. The ones used have just a metal tongue to lock the plug - which means that after some time - or less if you change connections often - the tongue or metal strip does not engage correctly any more, leading to nasty "frying bacon" noises.
Easy to remedy by bending the metal strp down again, but a pain in the behind. Problem is - I have not found a source for a board mounted replacement that would fit.
Other than that - I can only recommend the unit. Next one in line a K& H pro C 28 (i think thats the model) at app. 4000Euro. No discussion.
weissi
yes, itīs really a bargain... can get it for 230€ new! another 30€ for upgrade parts and you have a really good DAC also...
gmarsh
Both.
DSP is an abbreviation for "digital signal processing", which is a process. It's also an abbreviation for "digital signal processor", which is a type of processor which is specialized in doing digital signal processing.
DSPs are good at doing DSP... ;)
heineb
Hi everybody,
Now I've gotten the DCX unit to start up in upgrade mode but after several days of work I still can't connect to the unit - I've tried four different computers, two cables and both version 1.15 and 1.16 of the software but nothing works. It detects the unit alright but still once the transfer is about to start it says - "File sending not completed" - the unit itselfs says upgrade problem and needs to be restarted again - so it seems like there is some sort of connection. I've configured the com port alright like the manual says (115200 baud rate, 8 databits, 1 stopbit and no parity) but still no luck - it seems like I'm missing out on some basic thing that I need to do. Any suggestions ??
Best regards
Heine
werner2
Dear Heine,
yesterday evening I got the same problem like you with my Behringer Ultradrive DCX2496. So I checked Google today and found your post from 2005. I just registered to this forum but it is not possible to send you an email. They say that I have to make some posts first before I become a full member who is allowed to send emails.
Could you resolve the problem in the meantime ?
I tried 3 different computers, one with Windows XP, one with Windows 2000 and one old with Windows 95, where I could directly connext the RS232 COM port. Win2000 and WinXP was via USB-Serial adapter. I also checked two different cables an the software versions 1.16 and 1.16a.
Nothing worked!
In all cases the device was detected at COM1 or other COM portsm but in all cases the firmware upload was interrupted after some seconds (after 1%) with the medssage " !! File Sending not Completed !! Check Connection ".
Do you have a solution and help for me ?
I would be really happy!!
Thans a lot and best regards,
Werner
werner2
Dear Moderators,
I urgently need HELP on the Behringer DCX2496 problem.
I would like to send an Email to "heineb", but it is not possible. The forum software always tells me the following:
vBulletin Message
Sorry but you cannot currently send emails to other members because your account is under moderation. If you are a new user, you will gain full member status after you have made a few posts.
How many posts do I have to make in order to be able to send an email and to get some help ???
Why this ? This is really strange.
It seems to be the only way to posting some "dummy posts" in order to get rid of this strange blocking barrier ??
Best regards,
Werner
Netlist
I feel very generous today. :) You should be able to use the email system by now.
/Hugo
werner2
Dear Hugo,
thank you very much!!!
This was a very fast reaction, that is really great.
I am really frustrated that this Behringer Ultradrive DCX2496 was "completely killed" by trying to updating the firmware as officially described in the manual.
The hardware is now completely "empty", i.e. without any operating system.
And a reboot or reset does not work, all transmission attempts are interrupted after some seconds although serial COM connection seems to work.
How can Behringer release a product where the implemented software is erased BEFORE the load operation of a software update was successful ?? That's crazy.
Thank you very much, Hugo, for your help making me an active member with email rights !
Best regards,
Werner
Netlist
Werner,
You are most welcome.
Among the many DCX2496 experts over here, you could try to get Janneman's attention.
/Hugo
werner2
Hi Hugo,
oh yes, I will ask him, too.
Thank you very much for this valuable info and for your support!!!
Best regards and thanks,
Werner
Jusufs
Hi.
I have preprogrammed the internal EEPROM with the 1.16.bin file - my stupid decision :smash:
It should be reprogrammed over RS232 interface.
Does anybody have a contens backup from internal EEPROM AM29F040B ?
Thanks for help ;)
Jozef
Page generated in 0.055717945098877 seconds with 17 queries,
spending 0.00871539 doing MySQL queries and 0.04700255 doing PHP things.
Copyright Đ1999-2008 diyAudio.com
