diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Separated or Same Chamber Box? - Click HERE for Original Thread
suprastar17
Hey all,
I'm in the middle of building a sub box for two Rockford 12's. I was wondering whether it's necessary to seal them off from each other or whether they could share the same chamber? I read up on it at one point but never found any actual conclusions. What are the pros and cons? Any info would be appreciated.
Steve
simon5
You can use the same chamber. There's no pros and cons. Remember to use bracing if the chamber is large.
suprastar17
Thanks, I'm hoping to have it finished up in the next couple weeks. I'll put in some pictures when its finished.
Page generated in 0.022286891937256 seconds with 16 queries,
spending 0.01062369 doing MySQL queries and 0.01166320 doing PHP things.
