diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Service manual for Aleph 30 - Click HERE for Original Thread
Dennis Hui
Hi there,
Does anybody know where I can download the Aleph30
service manual? All the references I've found pointed
to the Volksamp site, which is no longer operational.
I also couldn't find it on the passlabs.com.
Many thanks,
Dennis
P.S. I'm a newbie who's lurked around for a little
while and have been amazed at the amount of information
available here. Hope to build an Aleph 3/30 in the future.
Nelson Pass
Mr. Harrington will move it over to the www.passlabs.com
site in the next couple of days for you.
Dennis Hui
Dear Mr. Pass,
Thank you so much.
Dennis
dharrington
Done! Here are the links.
Aleph 60 Owner's / Service manual
Aleph 30 manual
Desmond.
diyman
I've looked at the schematics of the Aleph 60 and it's quite similar to the Aleph 2. I am planning to build the Aleph 60 as the 60W is quite sufficient for me with lower heat dissipation. I would be grateful if someone could help me with the following:-
a) I noticed there are two resistors R1 and R8 in the A60 which
is not in the Aleph 2 and the values of these were not given.
Are they necessary?
b) The output of the mosfets are connected to the speakers thru
6 pcs of paralleled 3 watts 1R resistors giving a final
resistance of about 0.17R. Could I just use a non-inductive
resistor of say 0.15R in a 20W TO220 package by Vishay,
meggit, Mills etc?
c) For C17 in the balanced input, could I use a film and foil cap of
say 20uf to 40uf instead of an E cap of 220uf? Would this
affect the bass response?
ckt
Nelson Pass
a) R1 and R8 are trim resistor to get the last bit of
DC offset and PSRR. There is a thread elsewhere on
this site that you can search for.
b) Yes
c) Yes and Yes.
Page generated in 0.023741960525513 seconds with 17 queries,
spending 0.00776410 doing MySQL queries and 0.01597786 doing PHP things.
