diyAudio.com diyAudio Forums Archive > Top > Source > Digital
ÎÒµÄ1865NOSDAC.Lrak.2 - Click HERE for Original Thread
xiaolong
Meet this DAC's audition
My girl friend is said . Like having exchanged the small plate . Sound ( my girl friend does not understand sound ) that it is very beautiful
Bernhard
are you happy with CCa ?
quantran
When are you going to market your product? In complete kit form? Furnished PCB?
digi01
xiaolong is my friend.we have worked on team on the other projects.
to Bernhard
he work for a UPS company, designer.
PCB only,he has been busy:)
sch file available.
digi01
sch file,PDF vresion
kkchunghk
Looking at the schematic, the 74HC02 is sending inverse signals of Sdata and Fsync to the right channel of AD1865 and normal ones to the left. I've seen it done in a double DAC setup with balanced output. But I don't quit understand what the data structure is in an un-balanced setup such as this one. Explanation in simple English is much appreciated.
K K
philbyx
quote:
K K
No, No...
The same data on left and right. Only fsync is inverted between left and right.
This is the classical Audionote schematic.
We spoke here about this, and the nor gates could be replaced by simple inverters without major change in the final result.
Nothing very original here : I/U by a resistor, gain with a common cathode and cathode follower for the output impedance...
ECC88 I think, if we consider the psu caps : 50V + 50V, then B+<100V.
Philippe
MONTEFIORE
is your dac avaible as a kit
and how much
best regards
A MONTEFIORE
FRANCE
MONTEFIORE
dear sir do you know where i could buy AD 1865N-K
Many thanks
A MONTEFIORE
FRANCE
Page generated in 0.048928022384644 seconds with 17 queries,
spending 0.01759505 doing MySQL queries and 0.03133297 doing PHP things.
