diyAudio.com diyAudio Forums Archive > Top > Source > Digital
AD825 output stage:What bypass caps? - Click HERE for Original Thread
filholder
Hi
I am replacing the opamps in the output stage of my Arcam Alpha 5+
I am going to start with some AD825 though i also have go samples of AD8065 and AD8610.
What bypass caps values should i use for these?
Fil
Gasho
What bypass , on power supply or output?
For output you can use 4.7uF high quality polypropilen cap.
filholder
Hi Gasho,
No i was think of power supply actually. They are going to fit into Brown Dog adaptors and i have heard that i should do bypass to ground on V+ and V- and also have a bypass caps from V+ to V-.
But for these opamps i cannot find what values to use.
Any ideas?
Cheers man
Fil
fmak
[QUOTE]Originally posted by filholder
[B]Hi Gasho,
You will be amazed what 0.1uF npo caeramics (expensive) between V+ and V- will do for the sound! Try it.
Page generated in 0.019593000411987 seconds with 17 queries,
spending 0.00789976 doing MySQL queries and 0.01169324 doing PHP things.
