diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
bias meter and pot lead length - Click HERE for Original Thread
frank2395
based on diagram, (existing arrangment is inside chassis (chassis can not be altered)and i would like to make them external for ease of adjustment for tube rolling)
what length of lead can I use to make these (pot and meter) external i.e 200mm (based on noise pick-up etc)
Sch3mat1c
Doesn't matter unless the impedance of the driver is very high (211 amp eh? Yeah, you're safe...no one EVER uses pentodes anywhere...).
If in doubt, slap on a nice electrolytic from wiper to ground.
Tim
Enzo
That is a 1 ohm resistor. ANy noise trying to get in will have to overcome that low 1 ohm impedance. In short, nothing is going to get in that way. It will not be a critical bit of wiring.
Page generated in 0.016509056091309 seconds with 16 queries,
spending 0.00743175 doing MySQL queries and 0.00907731 doing PHP things.
