| bwbass |
I just put the finishing touches on my sub project and wanted to share and get some feedback.
It's a "folded" TL design, using a 12" sonotube nested concentrically (well, eccentrially, I suppose) inside a 16" sonotube. There's a 4 1/4" gap at the bottom of the smaller tube, which makes the "bend".
I had initially wanted to use 14" and 20" tubes, since the CSA's of both sections are nearly identical this way, but found that these sizes are uncommon and hard to find (and really big). I was skeptical of having the area of the first and second sections of the line differ, but after modeling the line in MJK's Tl Sections sheet, I found that the response actually looks quite good, with a broad flat fundamental peak from around 22 Hz to 65 Hz.
The design is intended for the Ascendant Audio Atlas 12, which I don't have yet, so sitting in for it now is my old Phoenix Gold car sub, which has a higher Q but nearly the same Fs and Vas specs.
So far, I'm quite stunned with the performance, especially considering the low cost. Bass is clean, powerful, and smooth, and extension in my relatively small listening room seems limitless!
The whole thing stands about 75" high; line length is 147". |
| bwbass |
| Here's a shot looking down the line from the top. The first half of the line is stuffed with about .5 lb / ft^3 of Dacron fill. I cut and wedged some 5/16" hardwood dowels sideways across the tube to keep the density even and prevent the fluff from all settling to the bottom. |
| bwbass |
This is my favorite part of the whole thing... the inner tube is just bolted to the outer one with some big old binding posts from Parts Express. The Atlas has two voice coils... one for driving and the other for adjusting the Q via resistive damping, so I put two posts at the top (for the RDO coil) and two at the bottom for the driven coil.
The finishing touch was some nice neoprene-backed sealing washers from Home Depot. Airtight, and solid to boot! |
| Tweeker |
$#@%! you beat me to it! Very nice sub. Im building a concentric sonotube tl too, but have a few too many other to dos to do on my to do list. Im having trouble finding the tubes I want too.
4 out 5 five people polled cant say the name of your city right:D |
| bwbass |
| quote: | Originally posted by Tweeker
4 out 5 five people polled cant say the name of your city right:D | Thanks!
What sizes of tubes are you considering? I'd recommend the heavy-walled versions if you can get them, as mine is a bit more flexy than I'd like... no rattles or offensive resonances, you can just feel quite a bit by putting your hand on it.
And people around here, against all logic, say "pew-AL-lup". That's where I work; I actually live in Olympia, which is much easier to pronounce. :) |
| Tweeker |
My grandfather lives in Shelton, fairly near Olympia. Was thinking about something crazy big before (20, 28sleeved30, 36) but it'd be an insane pain:dead: . Looking at 16,22,28 now. Plan to run bracers along the tube lengths tieing the tubes together for much more rigidity. Driver is mounted ~1/3 way along the line at the junction. The cone/motor forms part of the first turn. Driver is Avalanche 18.
______
You might be able to make your sub much stiffer by bisecting or trisecting the outer tube with a couple boards and glueing/nailing/poswting/screwing them on each side to the tube face. |
| bwbass |
You might be able to make your sub much stiffer by bisecting or trisecting the outer tube with a couple boards and glueing/nailing/poswting/screwing them on each side to the tube face. | Meh, it doesn't really bother me that much. I don't think the vibration is caused by pressure in the line, it's more the mechanical motion of the driver making the inner tube want to oscillate around the point where it's joined to the outer wall at the top.
I may get inventive and try to knock a wedge-shaped block under the edge of the small tube in the bend, bracing it against the floor. Have to find a way to do this on the end of a 7-foot pole, though! :)| quote: | | Driver is Avalanche 18. | An Avalanche 18?!? Woah. :bigeyes:
That's got a 16 Hz Fs, right? How long is your line going to be? My math says 17.5' or so... |
| bwbass |
16 - 22 - 28? Isn't the middle section of your line going to be narrower than the two ends?
I get about 1.07Sd - 0.91Sd - 1.17Sd, not accounting for bracing. |
| bwbass |
You might be able to make your sub much stiffer by bisecting or trisecting the outer tube with a couple boards and glueing/nailing/poswting/screwing them on each side to the tube face. | Sorry to keep replying to my own thread, I'm just thinking out loud...
You know, adding a board as a stiffening brace is a pretty good idea. If I just do one at the widest point of the crescent, maybe a foot long, I could wedge it in there and attach it with screws without having to take anything apart. And narrowing the line at the end a tiny bit with the brace can only lower tuning and smooth out the response a smidge, both of which are good things.
Thanks for the great idea! :) |
| Tweeker |
Hmm, its even worse after tube walls acounted for. Assuming half inch walls 16,22,26 would give: 1.07sd, 0.82sd, 0.62sd for a more traditional taper.
With an Ava 15 in there itd be 1.73sd, 1.32sd, 1.0sd. But Im going with an 18 anyhow. |
| bwbass |
That sounds better, and hey - being smaller doesn't hurt!
Though I don't think you'll have any walls that thick. I found this document very helpful in planning: http://www.sonoco.com/resources/fibreforms.pdf
Take it with a grain of salt, though. My 16" tube has .215" walls, which is not listed on that chart. Typo or a change in specs, I don't know. |
| Clarkcr |
I'd like to build one as well. Can you guys help me sift through the endless list of subs?
I'd like a freq response between 15 and 20 on the low side and extends to 40 or 50 on the high side. Okay, maybe 60Hz on the high sides. Of course staying relatively flat.
I have a 9 foot ceiling so, I was thinking two tubes, one inside the other, to create an 18 foot overall transmission line. Now, I could use an 18 and come close to hitting the ceiling (may not be a bad idea....I could use the ceiling as a brace and wedge the whole thing in like a pillar. Or I could play it safe and use a 15 inch sub and shorten as well as narrow my tubes a bit.
The monstrosity will sit back in an odd shaped corner of my 23 x21 foot living room. I have up to 30 inches diameter of footprint to play with here, so size of tube is irrelevant, only the height has limitations.
Again, I'm not looking for 10 Hz, just something between 15 and 20Hz.
Chris |
| SteveCallas |
| Excuse my ignorance, but by going with an 18' transmission line, isn't group delay going to shoot up pretty high? |
| bwbass |
I think the 12" in mine is quite sufficient for low-end extension IMHO. My listening room is longer than yours (it is open to the dining room), but with corner loading and room gain low-end extension seems to have no limit.
A 15" or 18" would work fine, though, as long as the line's not too tall for your room.
I would be careful about getting the end of the line too close to the ceiling, especially in a corner, lest the confined air up there "load" the driver and line. |
| Tweeker |
| If Im understanding the mathcad sheets correctly, even in a 210" line (tuned 16hz) with driver offset 1/3 down, group delay really isnt bad. |
| simon5 |
Well Clarkcr, the AV15 is currently one of the best deals available.
I don't know much about TLs, but there's alot of people with alot of knowledge on these.
I guess your 18 feet long TL would be really really nice.
Adire Audio will restock soon, not much choice beside that.
If you want cheaper alternatives, nice drivers on the PartsExpress website, like the Daytons... |
| GM |
| quote: | Originally posted by SteveCallas
Greets!
Some info I saved from an early Basslist thread. TLs 'shine' where it counts:
GM
Group Delay and Time Alignment
For a driver in a specific box type:
By definition, group delay is the slope of the phase response (the negative
derivative of phase slope). It describes the relative delay of the spectral
components of a waveform.
Group Delay = -[(phase@f2 – phase@f1)/(f2 – f1)]
A flat group delay curve indicates that all frequencies are arriving
simultaneously at the test point, while a peak in the group delay shows that
some frequencies arriving late. Typically higher frequencies will arrive
before lower ones, but not always, it depends on the design of the
driver/box, and more importantly the crossover. A typical group delay curve
will have a number of small (less than 1ms) dips and peaks.
Since the Qs of the system comes from the shape and absolute level of the
enclosure group delay curve,
a separate characterization has to be done for each type of enclosure.
For a closed box: Qtc can range 0.5 - 0.707 - 1.2
Qtc = 0.5 critically damped - transient perfect.
Qtc = 0.577 Bessel response (D2), max flat delay
Qtc = 0.707 Butterworth response (B2), max flat amplitude.
Qtc > 0.707 Chebychev (elliptical - C2), equal ripple response
max power, somewhat degraded transients.
As Qtc increases from 0.5 the group delay becomes greater and transient
response is degraded. However, independent sources have verified that any
group delay lower than 2ms is inaudible, and above 2ms group delay can
typically only be head in critical listening with headphones. In such an
experiment the group delay was introduced via electronic manipulation and
not inherit in the headphones themselves (fear not headphone buffs).
From "Perception of Phase Distortion in All-Pass Filters", by J.A. Deer,
P.J. Bloom and D. Preis as printed in the JAES, Oct, 1985:
"Results from listening tests indicate that a statistically significant
perceptual threshold is reached when peak group delay distortion at 2 kHz is
in the neighborhood of 2 ms (for diotic presentation via earphones)."
Loudspeaker guru Ken Kantor had this say about group delay:
“There have been many careful studies of the audibility of group delay in
loudspeakers and filters. Blauert, Lipschitz,
and the "Tufts" studies, to name a few. You can, for example, start with
the best, most "coherent" loudspeaker you can find, and degrade its time
performance using group delay filters.
What has been found time and time again is that "time alignment" effects
NOTHING in the quality of the reproduction until delays of well over 2 mS
are introduced, 10 times this in the bass.
I know of no published research to the contrary, other than snake oil and
floobydust.
Degradation of impulsive or square waveforms due to group delay is audibly
meaningless. Degradation of impulse response due to resonances or early
reflections, or phase differences between L&R are quite audible, on the
other hand.
To claim otherwise is both hard to support with published data, and is
contradictory to current models of hearing neurophysiology.”
Representative Group Delay by Enclosure Type:
Frequency Sealed Vented TL
10 Hz. 7 ms. 12 ms. 10 ms.
20 8 15 10
30 8.5 23 8
40 8.5 12 8
50 6 7 3
100 2 2 0
For a system:
The driver group delay is meaningless without consideration of the crossover
group delay. The 2nd. and 4th. order crossovers have much larger associated
group delays than that of the driver/box type. However, careful crossover
design can reduce the system group delay to well below 2ms over most of the
spectrum. Most commercial loudspeakers’ group delay curves exceed the 2ms
range in the low hundreds of hertz range. For examples just pick up a copy
of Audio or Stereophile and look at the graphs of any number of speakers.
Representative Crossover Group Delay Characteristics
frequency 1st. 2nd. 3rd. 4th.
40 Hz. 32 us 230 us 320 us 450 us
80 32 us 230 us 320 us 450 us
100 32 us 230 us 320 us 450 us
200 32 us 230 us 320 us 450 us
400 30 us 250 us 500 us 500 us
800 28 us 230 us 700 us 550 us
1000 16 us 220 us 680 us 450 us
2000 8 us 60 us 120 us 120 us
4000 ~1 us ~20 us ~20 us ~20 us
Notes:
1st order filter data for a Butterworth type.
2nd order filter data for a Linkwitz-Riley type.
3rd order filter data for a Butterworth type.
By E. Jakulis with additional comments by Jonathan Atkins |
| Clarkcr |
Well, I see the Tumult is now available, or at least up on their website. Which of the two 15 inch subs would be best for a TL line? The 15D2 or the 15D4?
With a little figuring, the area taken away by the 14 inch sonotube inside a 20 inch sonotube is roughly (6.28 sq inches off) the same. I could go to a 26 inch sonotube on the outside, an 18 inch sub on the inside mounted into an 18 inch sonotube, which leaves 12.98 sq inches of extra room (on the cross section) for internal bracing (3/4 inch wooded ribs.)
Can anyone calculate what my resonant frequency would be? Can TLs work this way? Here's a drawing. So, if it can be wedged into the ceiling (the top is closed off) I would think the bracing would be superior.
Am I way way off here??? Someone stop the ranting.
Here is a drawing of what I'm talking about.
C |
| Clarkcr |
| Alright, for those that care.....here is my goofy shaped room. As you can see, there is a hair pin corner that is essentially useless and is where my flatscreen goes....there is still a good 20 square feet back there. |
| Collo |
I'm not sure how important maintaining a constant cross-sectional area is, however if you wish to pursue it, the following might be of interest.
I built a test port which was made from three concentric tubes. I was hoping to find a new way to fit a long port into a short space. This is similar to what is being discussed here on a larger scale.
Whist the port itself performed poorly, some of the experience might be of use.
The main finding was that expecting the air to make a hard 180 degree turn at each end produced a lot of turbulence. For a TL sonosub, the airspeed would be much lower than this, but it probably wouldn't hurt to do some profile work on the ends to "help" the air around the corners.
The other thing that might be of value is the calculator I developed. It works out the pipe sizes and endgaps to maintain a constant area. Find it, (plus all the maths for the masochistic), at:
http://www.users.bigpond.com/bcolli...t-proof-adv.htm
regards
Collo |
| Clarkcr |
That is most cool!!! Okay.....a few questions. When you talk about adding and removing strips.....you're talking about cutting one cut through the length of PVC sewer pipe, then using a "strip" cut from another tube at the precise width as your calculator computes....to acheive the circumferance of the circle or the required inside diameter of said tube. This is done for ports 1, 2, 3 or 4 and 5 if desired. Abviousely the risk of chuffing is greater with more tube....so, if I'm aiming big with an 18 inch driver....I think I'll stick with the 3 tube calculation.
Can this calculator be done with a 2 tube only design? Height is higher....but chuffing is less of an issue. One must calculate the volume that the smoothed out inner corners would take up....no? Or would it change the "length"....maybe not? |
| Clarkcr |
Okay....wait a minute.....when making your own tubes, are you actually cutting down 2 tube, to in fact laminate together to make one new tube??????? Taking away from the inner tube to reduce diamter, then adding to a second tube to sandwich around the first one???
I'm dealing in inches, and with the wood/paper fibre sonotubes. How much is not enough difference in the stock diameter to worry about?? 1cm, 2 cm, 5 cm? (width of calculated strip)
C
PS Thanks for your help dude, this is great! |
| Clarkcr |
In addition....wall thickness of stock tube in port size calculator must be doubled. Right?
cool |
| Collo |
The way I made a tube of a certain size was to laminate two tubes together. Each tube will either have a strip cut out or inserted, depending on the size you need. You may in fact need 3 lengths - two for the layers and a third one to cut the strips from.
The calculator doesn't do two layer tubes, but if you are having trouble working out the endgap from the maths on the site, or if the demand is there, I'll re-write it.
The relevant equation is:
endgap_small_tube= ( ID_tube1 ^ 2 ) / ( 2 * ( ID_tube1 + OD_tube1))
I worked with PVC / epoxy glue, whereas you will be using sonotube as you said. I've not worked with sonotube, so I dont know if it can be glued. If its plain paper you could use PVA glue, but if it is waxed, I'm not sure how you will go.
If using a laminated tube in the port calculator, you use the thickness of your completed tube as the value for "wall thickness" ie double the wall thickness of a single sonotube
With regard to acceptable differences in pipe sizes, I suspect that a vaiation of 10% in volume (square root of this for diameter) would be fine. Probably best to throw this one open for discussion! :grouphug:
Adding a smooth bend at the ends could look something like the red area in the attched picture. The extra material would not change the calculations, because the endgap is calculated as shown by the brown arrow. |
| Collo |
Whoops! A couple of errors which could lead to confusion :scratch:
| quote: | Originally posted by Collo
The calculator doesn't do two layer tubes... |
should read "The calculator doesn't do two tube ports...."
I suspect that a vaiation of 10% in volume ... |
should read "I suspect that a variation of 10% in cross-sectional area ..."
The one good thing about having to add an edit, is that I get the chance to use some more of these wonderful smilies :mischiev: |
| Tweeker |
| Approach Im taking is to add pool noodles to maintain reasonably close to same cross section. |
| bwbass |
| Also, make sure to model your design in Martin King's MathCad sheets... I was more concerned about the difference in CSA in my different sections until I modeled it. MJK is also of the opinion that smoothing the bends in a TL, especially in the subwoofer TL, makes not a whit of difference. |
| Clarkcr |
| quote: | Originally posted by bwbass
Surely there is turbulance that will create a resistance of some sort. |
| Clarkcr |
Interesting....how so? I mean, used as dampening material? Cut in quarters lengthwise? |
| bwbass |
| quote: | Originally posted by Clarkcr
Surely there is turbulance that will create a resistance of some sort. | True, but remember that in a non-tapered TL, unlike the port of a bass reflex box, air velocity is relatively slow. If the cross sectional area through the "bend" is equal to or greater than that through the line, there's probably more turbulence to worry about around the back of the driver's basket, as air is being pushed through a smaller space there.
This thread contains some of my discussion with MJK re: corner reflectors and line geometry:
http://www.diyaudio.com/forums/show...6730&highlight=
Here is MJK and Bob Brines talking about TL bends and corner reflectors:
http://www.diyaudio.com/forums/show...0907&highlight= |
| Tehrasha |
I like the idea of a concentric folded TL. Im thinking of using PVC instead of sonotube. Weight isnt an issue for my application, and the rigidity of the tubes allows for a pair of ends to hold the inner tube centered, and then just a bunt-cake style reflector for one end.
Sound good, or just insane? |
| Clarkcr |
Sounds great but don't discount the sound deadening properties of the wood fibre sonotube. It is easier to cut, glue and comes in more sizes than PVC. I like the idea of slicing out strips in the sonotube to be able to make a custom diameter tube like the one fellow on this thread did.
Also, the bigger diameter sonotube is very strong. I don't think you would have any problem with weight.
C |
| MJK |
| quote: | | Surely there is turbulance that will create a resistance of some sort. |
Turbulance? Remember that the air is oscillating back and forth a very small distance in the TL, as frequency increases I believe the range of motion is going to decrease. There is no "flow" of air. I don't believe that turbulance is an issue in a classical TL, even in the folds. In a vented system with a restricted port it does show up if the system is pushed hard, but in a TL where the cross-sectional area is at least equal to the driver cone area, I have a hard time being concerned about turbulance. |
| Tweeker |
I looked at using pvc, the prices of the big bore stuff gets really really steep, didnt want to spend more on plastic than the rest of the system.
I was going to paint/tar the noodles so theyd be similar absorption wise as the rest of the enclosure. |
| planet10 |
Speaker Builder 1/90 (now audioXpress)....
dave |
| bwbass |
| Pretty cool, Dave, but that's not a TL, is it? Looks more like a sealed box with a fancy reflector at one end... or would that qualify as a bandpass design? |
| planet10 |
It is a TL. 15" bass driver fires down into the inner tube, folds at the bottom, and exits at the top of the outer tube.
dave |
