diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
ping Moray James: Hybird Karlson/TL - Click HERE for Original Thread
dw1narso
Hi Moray,
I saw some pictures of your hybird Karlson/TL loading for FR drivers...
Could you please elaborate more on this design...? I'm particularly interrested with it's small size enclosure... for FR drivers (which usually need big sized horn or MLTL loading...)
REgards,
David
moray james
David: I have been useing a somewhat modified line program very similar to the Alpha Line system designed by Rick Schults. I think that Dave Dlugos has a version on his site. I am most concerned with the Fs of the driver and pick a line length with the program. I usually make the line cross section about 80% of Sd. I damp at the driver end and along two sides of the line length. This keeps the line resonance high which is what I want. Then the overall line Q is controlled by useing either high density fiberglass or open cell foam at the terminus of the line. I run much shorter tapers than normal which usually stop at the bottom edge of the driver. I find that this combined with a curved reflector minimises the reflection problems often caused by the front coupler. I try to keep the cabinet width as narrow as possible which results in higher aspect cabinets which is good for bass response. You may well need to take into account the coupler length in the overall line length. I have been including the coupler length up to the bottom edge of the driver and have had good results. Don't ovet damp the line as a high Q resonance is necessary to make up for the fact that the line is so under sized. Good luck and keep posting to appraise us of your results. Best regards Moray James.
dw1narso
Thanks a lot for your input Moray,
David
planet10
quote:
I've not got the web version completed (far too little time to work on my site) but can mail the pdf...
dave
dw1narso
Hi Dave,
could you please mail me one... :)
Thanks,
David
(david_winarso_at_yahoo_dot_com)
planet10
quote:
It is actually sitting here:
http://homepage.mac.com/tlinespeake...aTL-article.pdf
dave
dw1narso
>>it is actually sitting here:
>>dave
got it ... thanks!!!
Page generated in 0.024393081665039 seconds with 17 queries,
spending 0.00734520 doing MySQL queries and 0.01704788 doing PHP things.
