diyAudio.com diyAudio Forums Archive > Top > Market Place > Trading Post
DH-500 heat sink assembly - Click HERE for Original Thread
Dick West
Here is a Hafler DH-500 heat sink assembly plus a free fan. You can see that the assembly has gaps in each 1/2 of the sink but this should not markedly effect its cooling ability. Just fill the gaps with some aluminum.
The fan is a Whisper Fan from 20 years ago. It has the motor in the hub so is not a strong starter. The impeller had an accident so is now glued onto the hub. However it should work for a long time, depending on the TLC applied. It only weighs a few ounces so won't increase shipping very much.
$25 for the sink assembly plus USPS parcel post for 6 pounds will get it from my house to yours. You can calculate postage from my ZIP 61111 to yours by going here:
http://www.usps.com/all/ratesandfees/welcome.htm
Pay Pal is preferred.
Dick West
Here is another picture of the heat sink assembly showing how this whisper fan is attached. The fixing holes on the sink for a fan have 4 1/8" centers.
The missing center fin in each 1/2 of the assembly will reduce cooling a tad. How much, I don't know. Probably not much and a piece of aluminum sheet could be instered into the air stream to help bring cooling back up to stock level.
Dick West
Sold!! Thanks for looking.
Dick
Page generated in 0.048111915588379 seconds with 17 queries,
spending 0.01829720 doing MySQL queries and 0.02981472 doing PHP things.
