diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
TA2022 power supply - Click HERE for Original Thread
simingx
Hi all,
I need a +/- 30V supply for a TA2022 amp that i'm planning to build, but I can only get 0-18 0-18 and 0-25 0-25V transformers here.
The 18V units would give me +/- 25V (a tad low) and the 25V units +/- 35V (which is marginally high).
Which one should I go for? I will be rectifying and filtering the two outputs from the transfomers seperately, so theoratically I will drop approx. 1.4 volts from each output, which would give me 23.6V and 33.6 volts... but I'd prefer not to rely on that.
Any suggestions?
mhelin
Use the 0-25 0-25V transformer is your speakers are close to 8 ohms, otherwise select the 0-18 0-18V transformer.
Page generated in 0.037420988082886 seconds with 16 queries,
spending 0.02594757 doing MySQL queries and 0.01147342 doing PHP things.
