diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
determine VA of unlabeled transformers - Click HERE for Original Thread
matt20102
Greetings, all
I've got several transformers from old dismantled audio components- a 1/4" RTR and sony receiver, to be exact. Is there any way to measure/determine the VA ratings of these transformers other than google searches (not helpful), equipment power ratings or the physical size of the unit itself?
One or more of these transformers is destined to become a part of a GC project with the LM3886. The transformers themselves are fairly large; the RTR transformer about 3lb, maybe ~3in^3; the sony (from a 120W amp with 4 simult. speaker outs) about 5lb, ~4in^3.
Thanks...
BlackDog
The equipment they came out of normally states a mains power rating on the back of the chassis....? Should be accurate enough.
pinkmouse
I was chatting about this with a guy who fixes old studio kit a week or so ago, and his rule of thumb is 1 kilo per 100VA.
I_Forgot
used to have info about transformer size vs. power. Hams were always doing things on the cheap, including rewinding power transformers to get the voltages and currents needed. There is a direct correlation between the core size and the power input/output of a transformer. I'll see if I can find my old copy and post the info later.
I_F
Page generated in 0.020514965057373 seconds with 16 queries,
spending 0.00753665 doing MySQL queries and 0.01297832 doing PHP things.
Please support our sponsor.
