diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
Fostex FE166E simulation in Hornresp - Click HERE for Original Thread
baggystevo82
Hi there,
I've been simulating a horn in hornresp and have a problem. Hornresp requires Cms in m/N, but if i do that, i.e. 0.00000182 for the fe166e, the results seem very strange and not what I expected. If I repeat but change it to 0.00182, as if it was asking for mm/N it seems fine, the spl result of which ive shown below. Any thoughts?
Steve
marcusf
Hi;
You can double click on the CMS box and fill in the values that it asks for and then the program calculates CMS. When I tried this with the values for the 166e, I get 0.00182, so I think you are right to use that value.
Hope that helps.
baggystevo82
ahhh, thats brilliant, thanks!
Steve
Page generated in 0.016590118408203 seconds with 16 queries,
spending 0.00802040 doing MySQL queries and 0.00856972 doing PHP things.
Please support our sponsor.
