diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
MLTL 206 Filter components - Click HERE for Original Thread
zotar
Trying to fine tune my MK MLTL Fostex 206, I now using Madisound Sledgehammer 3.0mH inductor, would the perfect lay type or Goertz type be an improvement? Using a Multicap 4.0uf film and aluminum cap, any suggestions? Tried a 3.0 Hovland and Auricap. A 4.5 ohm parallel resistor seems to give me the best balance. Thanks in advance.
zygibajt
I'm using FE 204 which is the older brother of FE 206, and is quite similar in parameters.
I got best results with 10ohm resistor, 4mH coil and 2uF cap.
Bartek
Toropkin
I got best results with 10ohm resistor, 1mH coil and 2,42uF cap
in parallel.
Driver - FE-206
weidok
quote:
I am using 1,8 mH and 8 ohm in a ML TL wih the FE 167 E
no caps at all !!!!
Do you have pictures and drawings of the enclosure
Toropkin
quote:
no caps at all !!!!
Please:
http://www.metaleater.narod.ru/ls2061.jpg
http://www.metaleater.narod.ru/ls2060.jpg
http://www.metaleater.narod.ru/ls206.jpg
- my system
Original blueprinting:
http://www.sloejd-kbh.dk/tema/speak...riko/jeriko.htm
zotar
The cabinet plans can be found at Martin King's MLTL website. I am surprised at the difference in filter network components being used by the readers. I started with the recommended filter by M.King and modified it slightly. Are you guys using the same cabinet parameters?
Page generated in 0.024458885192871 seconds with 17 queries,
spending 0.00797439 doing MySQL queries and 0.01648450 doing PHP things.
Please support our sponsor.
