diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
LM3886 Users Guide posted on Chipamp.com - Click HERE for Original Thread
BrianGT
I have now posted a users guide for the LM3886 kit on my website:
http://www.chipamp.com/docs/lm3886-manual.pdf
Sorry for the delay in getting this manual out.
If you have any farther questions, drop me an e-mail, and answer them for you, and work more material into the manual.
Brian
SheldonD
Brian: you need to edit the previous post as one gets url not found
maxw has given the corrected url below:
DT
very nice manual. :up:
But why in 2.3 Chassis Considerations you are using metal bolt for transformer mounting? Maybe brass bold or plastic strips would be better for this purpose?
BrianGT
This was more of an issue of what is most commonly available. Brass bolts might be better for this purpose if you find an easy source for them.
Brian
digi01
in time.
homer09
MISTAKE: Section 1.7 point 1, pictures are inversed.
UrSv
quote:
Brian
Well, it wouldn't make much difference would it or has somebody proved that brass bolts sound better? After all toroids have been mounted almost exclusively with normal standard steel bolts almost since the Jurassic period.
Great work Brian!
pmkap
While I'm not going to enter the metaphysics of bolt material fray, both nylon and brass bolts and nuts are generally available in any real hardware store, in the plumbing supply sections. Its generally what is used for affixing toilet seats, bowls, etc....
BrianGT
quote:
Fixed. Thanks for pointing this out.
Brian
BrianGT
Also, keep in mind that the picture shows "what not to do", and is an example of how a shorted turn would occur. Using a plastic strap would avoid this problem, or proper rubber washer.
The shorted turn is a common problem, as this section is an attempt to avoid it.
Brian
Peter Daniel
Non ferrous metals are conductive ;)
BrianGT
quote:
Indeed they are ;)
Brian
Peter Daniel
One way to avoid shorting condition, is using epoxy filled toroids, with a nut coming from the bottom. This type also allows more clearance, as the metal cap on top is not required. All Plitrons can be ordered this way now.
Eric Weitzman
Page 11 second last paragraph:
quote:
The fuse required will be dictated by the size of the transformer, due to the inrush current when power is first applied. A 2 amp slo-blo typically works fine for transformers around 220VA or less, while a 3 amp slo-blo fuse might be required if using a larger transformer.
A question (not an answer): Isn't the inrush current determined by the size of the first cap in the power supply?
Page generated in 0.033370971679688 seconds with 17 queries,
spending 0.00667214 doing MySQL queries and 0.02669883 doing PHP things.
