diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
My LM1875 gainclone... point2point... - Click HERE for Original Thread
w00t
Finally got down to doing my gainclone... Everything used are spareparts leftover from previous projects... :D
Resistors:
Zobel uses 5W Dale 1% NS-5.
Carbon 5% used between ground and earth, and for LED.
Everything else 1% metal films.
Capacitors:
4.7uF Blackgate-N for input dc blocking.
Wima 0.22uF MKP for zobel.
Nichicon Muse 1000uF per rail per chip for PS filtering.
1uF MKS used across both rails, soldered directly onto chip.
0.1uF used between ground and earth.
0.1uF Rifa X2 used as snubber caps.
200VA 18-0-18 toroidal trannie used. Rectification by ON Semi MUR860. Binding posts are all WBT clones. :D Heatsink is oversized for this application... Hardly gets warmed up. :D
On with the pictures... :D
(Ignore the Earth wire around the binding posts... it's there to add 'thickness' so that the binding posts can be mounted properly)
Right channel done... Left channel half done...
w00t
Closer view of the Right channel... Took great pains to solder it 'star'...
w00t
Both channels wired up to the power source...
w00t
Another view...
w00t
The rectifier board... Check out the wires converging at the DC side...
I have no uniform wire color code for different voltages...
w00t
Overall view... :angel:
w00t
Back view... the WBT clones, 2 RCAs, a fuse holder (hardly visible) and the IEC (hardly visible as well)
w00t
Testing in progress...
That's all! Comments? :D
MBK
That's great, your soldering work looks as messy as mine :D (and do I recognize Sim Lim prototyping boards?).
Not to worry too much, the electrons don't care. But do check out safety, sometimes without the "anchor" of a board, and with thick connecting wires, things can get bent into a short, with those tight spaces. I have made this kind of mistake several times...
Have fun and enjoy,
BlackDog
Hi there - how does the amp sound, and what speakers are you using with it?
I also noticed that in post #3, the top of one of your supply caps looks VERY close to touching the tab of one of the rectifirer diodes. I'd look at that if I were you.
(I think the metal casing of most el. caps is connected on of the terminals..)
Nuuk
You may find it easier to use solid core wire rather than the stranded. It makes for easier soldering in tight spaces and (IMHO) sounds better.
Other than that, a good job. ;)
w00t
Have fun and enjoy,
Haha! The wires actually appears to be more rigid... my excessive tinning seems to have tinned the inside of the insulation. :D
The sound is great! Don't really know how to describe its sound. Perhaps I should say they sound rather 'balanced'. I'm using them with KEF Cresta 1 speakers.
As for the supply caps, that's just the camera angle. It's actually a fair distance from the rectifiers. :)
Thank you! :cool:
As mentioned above, the stranded are actually quite rigid after my excessive tinning. :D Solid cores can let me have a neater layout, but they are far too difficult to bend under such tight spaces. :( Might try them out in the future. :D
Nuuk
No really if you use 0.6mm and I have even hardwired a Gainclone with 1.0mm!
skyraider
Just curious, with such a big transformer why didnt you go for higher power opamp like 3875/3886?
Or is it that you just prefer 1875?
w00t
Have tied many times with the 3875/3886, but always end up with massive DC offset... :(
So I did up the 1875, til my planned tube amp can be realised... :D
skyraider
I would try to tackle that DC problem first, if I were you.. 3886 is much better sound. But if you are happy with 1875, no problem. End of this issue.
Did you try using different resistor for the zobel?
w00t
Hehe... :D
This project was built with spare components entirely, so I'll just leave the zobel as it is. :D
mod_evil
Ohhh... very good constrution... simple and easy...
Please post the schematic... do you use the datasheet schematic or you construction one schematic?
Thanks for attetion.
w00t
Thank you! :D
The schematic is basically derived from the datasheet, with some values changed, components added/omitted.
With regards to this schematic (http://202.186.86.35/audio/articles...ile/diyden2.gif), R1 was changed to 47k as I had these resistors on hand. A 4.7uF BG cap was used between the RCA (J1) and R1 to block DC. C1 was omitted and R4 changed to 18k. I don't really require the high gain, so I slightly lowered it.
Cheers! :)
mod_evil
Why do you not use the RC filter in the inputs?
The schematic is very well...
Thaks for schematics and the replys.
DC Dave
Why not add two more channels?
Your tranny is plenty big enough, and your heatsink has enough room for atleast four chips, maybe more.
It would not cost much to add two more channels.
Just a thought.
w00t
The RC's purpose is mainly to block out DC. I feel extremely uncomfortable without a resistor to ground after the capacitor. Corner frequency is calculated to be at around 0.72Hz. :D
Just a thought.
I have no need for more than 2 channels. :D This amp is mainly for my stereo setup. My HT's using commercial amps. Don't wanna risk something blowing halfway thru the show... :o
Page generated in 0.052589893341064 seconds with 17 queries,
spending 0.00871992 doing MySQL queries and 0.04386997 doing PHP things.
Please support our sponsor.
