diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
Completing my DIY TT - Click HERE for Original Thread
fortytwo
Hello,
I am currently working on my duy turntable again. ANd i am finally gonna gt it done this time. MY whole picture is to have a seperate system, (turntable, motor pod and 2 tonearm pods) I will have a drilled material (mdf or plexi) as my foux shelf (holes drilled intoit to keep most componets in the same place). This will have 4 isolation feet prolly sorbothane or just wood or dampening material. I am having a bearing machined this week alonge with all remaining parts to get just the turntable together. The pods will be next couple of weeks.
Now the questions.
I have the plinth made out of acrillic 1 inch thick (2.54mm) and a bronze / stainless steel bearing hanging down in the middle. the legs are about 3.5 inches anf about 1.5 inch diameter. These i salvaged and are connected to a center rod with a set screw, the center rod has a pointed foot screwed onto it. and to hold it to the table there is a sleve with a set screw on top of the plexy.
question #1
Should i put a compound (contact cement) between the pointed feet and legs to advoid a vibration?
question #2
I was thinking of putting a 1/4 or 1/8 inch layer of sorbothane between the plinth and the leg and the sleve holding it on. @ reasons first togive adequite pressure (like a strong spring) and second to isolate it. when i tighten it i will put a weight on top of the collar possibily 10 pounds, to peload the sorbothane.
what are you thoughts on this construction. I am trying to save my self errors before i put it together, whitch will be when i get the bearing.
I have no recent pictures, but there are some here of the bad bearing of the plinth and plater.
http://www.spootystuff.com/projects...e_building.html
these pictures are real old.
thanks and a tip of my hat to roger waters (got me to finally finish my table) and someone who i forgot their name but has a awsome design of cutting boards and alumun.
FortyTwo
analog_sa
Every small bit changes the perceived sound. As the materials you mention all have nil isolation properties at low frequencies all they'll acomplish will be modifiying the sound in the mid and high frequencies. Unless you actually listen to it there is practically no way to predict whether the change will be pleasing or not.
From my limited experiments with building i have noticed that the arm support has probably the strongest effect upon the sound. Of course plinth construction, glues and pointy feet are all very noticeable. A plinth i made changed dramatically from being just bolted from several layers of ply to being lead filled to being glued. Yes, i agonised over the type of glue - it does become a part of the plinth, but at the end just used epoxy.
fortytwo
I will have to give it a try either way, i can then change the height between the leg and foot to compensate for the lack of sorbothane. I have this flexibility because of the construction method.
Therefore hainge alumun against acrillic is ok, there is no need for something between them?
FortyTwo
fortytwo
I am sorry but i cant seem to find a thred (or part of a thred) that had somes very astecially pleasing diy tt. IF someone could help me find it and point me twardws it i would like to copy his motor / tonearm pods and ask him a question.
The table was made from marine alumun and cuttingboard plastic. It has seperate pods for the tonearm and motor had a funkey shaped 3 footed base with huge ball bearings on the top of each foot section.
Thats all i can remember and describe well.
FortyTwo
fortytwo
Found the table.
GazzaFloyd. Very nice table design.
I put a link up on my website.
thanks
FortyTwo
GazzaFloyd
thanks for the complement best of luck with yours if i can help drop me a line
fortytwo
GazzaFloyd
I belive that any effort to truly get a unique design is commendable. Yours has one of the magor rules of building a DIY TT and that is great style. I am truely in live with the art-decco design, and i belive we arekeeping that mechanical look alive today.
I do have a question nabout your pods (motor and tonearm). How did you make the top and bottom. Did you machine a grove intothem for the cylinder to sit into or are they flat and have some centering pins in them. I would like to end up with something quite simular.
Currently i am still waiting for the bearing to come back from the machinist so i am building a roger waters style tonearm out of acrillic and carbon. If my parts come back i will finish the turntable
FortyTwo
fortytwo
I just got my bearing back today. I polished the staiunless and also the bronze. Here are a few pics of assembly. Now all i need to do is build a motor assy and tonearm pod and i will be listening on it.
This pic is of the bearing after polishing and i am just about to assemble it.
fortytwo
Here are some pics of my tone-arm parts i am making
fortytwo
Finally here is it all assembled.
The core part of my DIY TT is complete.
GazzaFloyd
Thank for your coments
as to my pods the top and bottom plates sit inside a 100mm peice of pipe with notches in the sides to keep them centered they are tied together with threaded rod
GazzaFloyd
sorry about the bad photo
GazzaFloyd
i am very please with this:cool: :)
promitheus
very good work!
:bigeyes:
Where did you make the bearing?
GazzaFloyd
From my original thead :
quote:
So the first thing i did was get a local engenier to make me a bearing i have ended up with a very close copy of the Teres Audio Bearing cost on this came in well under US$80 the outer portion made out of Bronze the inner out of Stainless
I may still have the drawings if you are intersted let me know will see if i can find them.
Thanks Garry
kilowattski
I am also very interested in your bearing drawing.
GazzaFloyd
sorry guys i know longer have that drawing
fortytwo
Just updating you guys on recent progress on my table.
I have my pods completed, I took thinkwall food grade stainless steel pipe welded a bottom into the motor pod about 1/2 inch up and the machinist came up with threding on the tops, gives a nice clean look. The tonearm pod is half the pipe and the other half is part of a copier drum pressed into this then capped in a simular way. I have a secong lower tonearm pod made and i plan on finishing it when my tonearm is done.
Now all i haver to do is get and install a motor and controller.
fortytwo
Here are some closeups of the pods
fortytwo
quote:
quote:
Here is my drawing i used. I drew it based on Gazzafloyd 's table and teres a bit.
The machine tachnician made a few modifations to it, he used bronze instead of brass. He also used my previous steel bearing mount and machined the grove out of it and pressed in the bronze. This made it cheaper less matrerial removal time and i had the other one allredy mounted.
Use at your own risk, have fun.
fortytwo
I have finally completed my turntable project. I still have some bugs to work out with the tonearn and alignment. But the table is completed and working. As you can see on the right i have a old peice of test equiptment that has a 24volt transformer in it that i converted to my power supply/ motor controll unit. It houses a Mark Kellly group buy pc set. The larger board is visible through the cage on top while the adjustment is on the bottom accessable by turning the unit on its side. I plan on either mounting a dummy tube in it as a indicator light or something else that looks cool. The motor pod is a maxon (group buy) motor with it half full of shot gun buck shot. Runs quiet and sounds great. I will be posting some more detailed pics shortly.
FortyTwo
fortytwo
Here is the bottom View of the power supply. I mounted the pcb by bending 14 guage (house wire) solid copper wire with loops on the ends. Soldered the loops togehther and bent into place. I can now bend the board out slightly to gain acess to the adjustment pots.
Nanook
is that your diy arm? if so closeups please, and what a stunner.
stew
fortytwo
No sorry that is my original Rega RB200 with a weird headshell. I plan on finishing my arm next. I have half of the peices made but still having trouble finding the right bearings.
Nanook
check ouyt the usual suspects, McMastr&Carr, Small Parts Inc., etc. .
Let me know what ya need and I'll see if I can help. Nice looking pieces for the gimbal, but light in weight.... wouldn't extra mass at the pivot help reduce effects of inertia on the arm?(just a thought)
good luck with the tonearm, the table looks absolutely great.
stew
Page generated in 0.27839088439941 seconds with 17 queries,
spending 0.13533497 doing MySQL queries and 0.14305592 doing PHP things.
