diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Chinese GC - Click HERE for Original Thread
iamwiam
i am a newbie here~~~and my GC:) :) :) :)
peranders
I'll guess you'll have to upload your picture once again.
iamwiam
The picture is too large~~here are the new ones
iamwiam
:D :D
iamwiam
:whazzat: :whazzat:
iamwiam
:xeye: :xeye:
iamwiam
:clown: :clown:
commstech
Nice work there..............but i don't see anything Chinese about it...:clown:
iamwiam
like this~~~ÄãºÃ~~~ÕâÊÇÎÒµÄÊײ¿GC×÷Æ·~~~Ò»²¿Ñ§ÉúµÄGC
iamwiam
:D :D
iamwiam
How Can i upload all the pictures in one post??
iamwiam
iamwiam
;) ;) :xeye: :xeye:
iamwiam
:o :o
iamwiam
iamwiam
iamwiam
:cannotbe: :angel:
iamwiam
:o :( :)
iamwiam
iamwiam
iamwiam
;) :xeye:
iamwiam
:xeye: :xeye:
iamwiam
:hot: :hot:
iamwiam
:apathic: :apathic: :bigeyes: :bigeyes:
iamwiam
:smash: :smash:
iamwiam
:D :D
jcayer
Very nice :up:
Very clean :up:
How do you like the sound ?
iamwiam
quote:
Originally posted by jcayer
Very nice :up:
Very clean :up:
Quite impressive. i am impressed by its good mids and highs~~and the sub-bass performance is good too!
I_Forgot
I see your level control (or is it a power switch?) is on the front panel with the wires running past the power supply boards. Do you have any hum or buzz in the output?
I like to keep low level inputs away from anything that carries a lot of current (like power supply wiring) or radiates noise. In your very attractive box, you don't have a lot of room to play with positioning of boards, but I would have tried to keep the pot near the input jacks, and keep power supply wiring away from the audio stuff except where the DC connects to the amp boards. If you must run AC power or power supply wiring near the jacks, run it past the amplifier's low Z output connections, not near the hi-Z inputs...
You can mount the pot on an L bracket and extend its shaft to the front panel using a piece of brass, aluminum, plastic, wood, or bamboo tubing (whichever sounds better to you ;) - hah!).
Always use a star ground for minimal noise!
I_F
edjosh23
I can tell you, your no noob. :bigeyes:
Those look very nice.
Josh
karma
very nice:smash:
iamwiam
I_F
Yes, That's a level control ! At the first, i decided to use a shield wire connect the signal in to the amp, but after failing to find a suitable shield wire for it, i use a normal wire instead! To my surprise, the sound turned out to be very clear, without any hum or buzz !
Besides, The aluminum case is connected to the earth, this can prevent the amp from making radiates noise.
Still, thanks for Ur suggestions!
Page generated in 0.044656038284302 seconds with 17 queries,
spending 0.00771832 doing MySQL queries and 0.03693771 doing PHP things.
