diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
Turn on/off thump with "others" D amps...how it is managed? - Click HERE for Original Thread
pat allen
Hi, i am wondering how the turn on/off thump is managed on other modules like UCD or ICE modules. Do they have thump might be the initial question.
If not, how the design permit a direct connection from the LC filter to the speaker?
As an example, my IR redisign uses a mute relay because upon turn on, there is a dead time forced to charge the bootstrap cap. I know UCD or ICE module differ a lot, i am just wondering because it looks like there is no relay at all.
thanks.
Jan-Peter
Pat,
Indeed in the UcD modules we do not have any relay. We switch ON/OFF the currentsource of the two PNP differential input transistors. Please check the schematic from the UcD what is yet public known.
Jan-Peter
Pierre
Is there a link for that schematics? Or you refer only to the UcD patent?
Thanks!
Jan-Peter
Pierre,
Please check this http://www.diyaudio.com/forums/atta...tamp=1110300548
Jan-Peter
pat allen
Ok, so there is absolute no turn on/off thump?
How is the current source turned on/off, with a constant simple delay, microprocessor controled, manualy??
Is it totaly self contained?
Is there some active protection on these UCD modules?
thanks.
Jan-Peter
Indeed there is only silence when you switch the UcD amp on.....:D
(however to be honest, when you put your ear in front of the loudspeaker you will hear a very small "thick")
We wait for one second so that the bootstrap capacitor can be fully charged, and the we switch the current source on.
We use this ON/OFF part to switch OFF the UcD when there is an overvoltage. In the first version of the UcD180/400 we used a piek current protection hereby was also this mute section used.
However we use now a constant current limiter in the UcD modules, this works in a different way and is confidential.......;)
Jan-Peter
pat allen
Thanks.
Sorry to ask, how can the bootstrap cap be charged if Vout=0?
In my understanding, it have to be -vcc as long as it needs to be charged?
Jan-Peter
Sorry, confidential.......;)
But it works :D
Jan-Peter
pat allen
Ok, i think i get it anyway....while i was playing with the PB12 module, i was "forcing" the bootstrap cap to be charged...it is grounded by the speaker resistance then, so...
thanks very much.
ghemink
thanks.
As Jan-Peter said, only a very small thump when you put your ear close to the speakers. I have these modules directly connected to my tweeter, midranges and woofers (active system). Very well on/off switching behavior. No relay needed in between amps and speakers.
Gertjan
classd4sure
Thanks.
Use a high value pull down from the switching node (bootstrap virtual ground) to the negative rail to ensure it has a precharge path under all conditions (no load), 47K ohm's for instance would be just fine.
Then, use a resistor + series diode from the VDD rail to the positive side of the bootstrap cap with a paralled zener across the cap of a slightly higher value than the negative supply, this way it will drop out of function during normal operation while ensuring it doesn't overcharge while not oscillating. Keep it close to the same value though, you don't want it to precharge to 15V with a 12V negative supply.
The series resistor in question will need to be sized according to the diode and zener current, how fast you expect it to charge the cap, and how big a "thick" you can stand. Also, if it is too small, it won't allow the zener to drop out under normal operation, and will keep the cap fully charged to the zener's level.
The bigger the resistor, the lesser the "thick", and the longer it will take to precharge the cap before you can enable the output stage.
You could also use a relay, flip flop perhaps retriggerable monoflop maybe, PIC, etc. to switch out the series resistor+diode precharge circuit and enable the oscillator, but it's not necessary if you do the precharge circuit right.
Non of that will help the thump from a DC offset caused by the input stage imbalance though, so that should be zero'd.
Chris
lumanauw
I saw the bootstrap cap in other classD schematic is below 1uF. Here in the Guestimate UCD it is used 100uF. Could this be dangerous or it's OK tobe overvalued?
Page generated in 0.033457040786743 seconds with 17 queries,
spending 0.00784945 doing MySQL queries and 0.02560759 doing PHP things.
