| wuffer |
| can anyone recommend a small amp about 20-30 watt, easy to make.. i was thinking of making speakers for my pc and i would like to try the fullrange... |
| Nuuk |
Perhaps you cannot 'see the woods for the trees'! ;)
A chip amp is what you want and you are welcome to start looking here
Then follow the GC web ring and you will have all the information that you need. :att'n: |
| wuffer |
thanks... just that site i was looking for...
so many designs.. what should i go for... |
| Nuuk |
| quote: | | so many designs.. what should i go for... |
My suggestion would be an inverted design using a buffer. Buffer choice is down to what you feel comfortable building, they all sound very good with a GC.
All the designs on my site use the LM3875 but I ahve just built one with an LM3886 that sounds very good too. etails will be posted on DD when I have time.
And don't forget, if you are not happy to build from scratch, there are several people offering PCB's and/or kits. ;) |
| wuffer |
thanks.. i think im going to build it from scratch..
it dont seem very expensive so im going for it :) |
| mod_evil |
| Why you use the LM1875 for 20w and LM3875 for 50 ~ 60w ? |
| wuffer |
what should i use for a volume control??? im going to build it in the same case... nothing fancy or expensive.. only going to use 1 input....
im not sure if i should go for the LM3886 or the LM3875. the price is the same.. going to make a amp for a small 6½ inch sub |
| Nuuk |
Use the LM3886 for a sub, it will give a bit more power.
And if this is for a sub, any pot will do. Try a 20K or 50K log. If you want specific recommendations, then search this forum. ;) |
| wuffer |
thanks.. then i will get 2 LM3875 and 1 LM3886
it was for the stereo amp.. but i will search som more :) |
| mod_evil |
| quote: | Originally posted by Nuuk
The datasheet specifics one pot 10k
Thanks |
| Nuuk |
| quote: | | The datasheet specifics one pot 10k |
Yes, that's fine. That's what I use. ;) |
