diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
Looking for subwoofer classD using TL494 - Click HERE for Original Thread
lumanauw
Does anyone has built a simple classD (subwoofer amp) design using TL494 or SG3524 (PWM driver)?
IVX uses TL494 in the SMPS section, what I look is TL494 in audio section.
bigbulb
TL494 will not be stable when operate at frequency higher than 180KHz, the build in comparator (error amp) can't give you high slew rate, and produce more distortion.
Leolabs
I do come across Class D amp using SG3524,try this
http://schforfree.seedhost.com
Page generated in 0.092576026916504 seconds with 17 queries,
spending 0.06335402 doing MySQL queries and 0.02922201 doing PHP things.
Please support our sponsor.
