| Cheap 12" sub - MCM 55-1255 - Click HERE for Original Thread |
| bigwill |
I've found these cheap 12" woofers:
http://mcm.newark.com/NewarkWebComm...SKU=55-1255&N=4
Can anyone find any TS parameters on these? I'm having a bit of trouble. Even without TS parameters, would I be able to make a decent enclosure for them? I'm thinking of making some cheap stereo subs but all the cheap woofers don't seem to have any associated data :( |
| bigwill |
| That PDF is excellent! Many thanks! |
| richie00boy |
That woofer would only be any good in a sealed box due to the high Qts. I assume it's stocked by CPC or Farnell and that's why you are checking it out?
You might like to have a look at BK Electronics and their BSB12-100 driver which is broadly comparable with that one. |
| bigwill |
| I've found much better woofers from CPC now I have the TS parameters on almost all that they supply :) The originals I questioned were wild stabs in the dark and turned out to be pretty bad! |
| mike.e |
| farnell seems to have some real crappy drivers:xeye: |
