diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
Suggestions before I cut the wood? - Click HERE for Original Thread
mazeroth
I have four Hi-Vi B3N 3" full-range drivers sitting in front of me and I want to try a pair of open baffle speakers for my computer. The baffle will be made from 3/4" birch ply and the base will be 3/4" MDF. The dimensions I have now are 14" tall, 6" wide. I will be putting the driver 1.5" from the top, and offsetting it 1" from the side so no sides are equidistant. Because it's plywood I'd rather not roundover the baffle. I will be using a 45" chamfer on the back of the cutout to let the woofer breathe. I did a test with cardboard this size and it's really lacking bass so I will be adding a small sub and cutting ~150hz off from the Hi-Vis.
Aside from what I mentioned, are there any other suggestions? These will be on top of my computer desk and will only be about 1 to 1.5 feet from the wall.
Thanks!
johninCR
In the nearfield I wouldn't use multiple drivers unless you are going to use 5 or 6 per speaker and make a small array. Small OB arrays are great at your desk IMO (huge sound for at your desk).
Also, Linkwitz says center the drivers, which looks better to me anyway. The rectangular shape give plenty of variable distance around the baffle. Plus your monitor is going to change the effective baffle width anyway on that side of the speaker.
Page generated in 0.022381067276001 seconds with 16 queries,
spending 0.01037478 doing MySQL queries and 0.01200628 doing PHP things.
Please support our sponsor.
