| hclisen |
| From TW bay, anyone use this as loudspeaker?How it sound?Any suggestion please, thanks a lot! |
| qwad |
| :xeye: just my personal experience of philips speakers[ tho not the full range l must stress...] they are not very good and lo tech, straight sided cones and very ragged response, which l imagine would be exaberated in the fr version , the plain vanilla versions sound hard and shrill, just as most philips drivers do so l would not recomend them, just my 2 cents worth though others ears are different to mine ,,,, so give it a go and see if you do like them:o and let us know how you get on;) cheers TC |
| hclisen |
| Philips AD 80800/M4 |
| Rudolf |
| quote: | Originally posted by hclisen
Philips AD 80800/M4 | The official spec sheet (T/S parameters not included) is published at
http://www.audiodiskussion.de/foren...g.php?idx=12277
The diagram shows SPL and nonlinear distortion. This is a run-of-the-mill-fullranger, nothing special. Someone in the thread above recommends 5-7 l closed as enclosure - though without much bass. Sensibility is 93 dB. |
| tomtt |
personaly i find them wonderful
perhaps you should try them first,
in the event you don't want these i'll
buy them |
| hclisen |
| It`s very cheap and the seller owns lots stock(more than 6,000 pair ).Actual its very cheap, w/o shipping charges it only 12 USD each, and 9 usd /each while order over two pair.Maybe can try it! |
