diyAudio.com diyAudio Forums Archive > Top > The Moving Image > LCD
Strip a Proview PL576Ws 15.4" 1280x800 wide screen LCD monitor - Click HERE for Original Thread
18wheeler
I finally picked up a proview PL576Ws at local Staples for $229. It might not be the best LCD on the market, but I believe it is the best LCD for a DIY HD Projector.
The LCD module used in this monitor is Toshiba Matsushita Display LTD154EX0HG. I found MAG PS576W uses the same module, so I copied spec here:
16.7M color
0.259 pixel size
1280¡Á800 native
300 cd/m2
400:1
25 ms
100¡ã/ 90¡ã
D-Sub
internal speakers
36W
External power adapter
3.3Kg
The box:
18wheeler
remove two screws at back lower edge
18wheeler
The front is now removed
18wheeler
remove two screws near speakers ...
18wheeler
and the one near the post on the back
18wheeler
and the back cover can be removed now
18wheeler
Optional
you can remove the small cover that reveals wires from controller to LCD. But it is not necessary.
18wheeler
remove a couple of screws on the side, the back metal panel was move aside to reveal the backlight plugs.
18wheeler
now the two halves can flip open, and the backlight is ready to remove. there are 3 small screws on the side and one on the metal cover on top of the PCB board(it was removed in the pic)
18wheeler
flip the PCB board up and the backlight was easily removed
18wheeler
now a quick test on a 3M 9200 OHP. the stage is too small for the LCD (only 10" or so), and it is kinda dirty too. But it give you an idea how it look from up to bottom.
18wheeler
The LCD on 9200's stage
18wheeler
As you can see, this monitor is very easy to strip, and performs well on a medicore OHP. for $229 it is must-have if you want true HD quality.
Enjoy it.
Inkog
Thanks for posting this, it answered alot of design questions for me while allowing me to keep mine as a tv until I get my optics.
Do you mind sharing your ideas/plans for this LCD?
Clinton
Not sure if this has been asked yet or not, what are the dimentions of the LCD once stripped?
Clinton
Ben_Tech
13 1/4" x 8 3/8", approximately.
WMT
Hello,
i allready have a proview PL-576Ws almost a year now and it performs realy well with a HQI-TS 400W D and an 18" beseller with 550mm fresnel.
I recently found this monitor:IISONIC TFT 15,4" IIM15J (16 ms)
and i wonder if it uses the same lcd module as proview.
This is the site of iisonic:
http://www.iisonicasia.com/lcd-mode...hp?productid=27
Does anyone know anything about this?
NeMeSiS_singh
yes, its the same lcd.
its the only one made that is 15.4inch widescreen that uses 256k colours.
WMT
Thanx for the replay.
The only thing that was confusing me was that IISONIC stated that the resolution is 1280 X 768 but they say that it supports 1280 X 800 with pc.
I thing that after the 1920 X 1200 15.4" tft this one is the next best for diy projection as it strips dead easily and it performs very well.The only thing that i noticed is that by removing the antiglare film it does not become more transparent and it has image reflecting problems even with an antireflect coated projection lens.
Nickmunstr
Hi everyone... I found this post from google...
I am in the middle of a projector build and my 15.4" x2Gen cracked on me today... A huge let down.
I am looking into this monitor and wondering what people think of it... What is its refresh rate?
Also, I noticed some anti-glare issues above... Have you guys been taking the anti-glare off with just water/paper towel, or is it a trickier monitor?
Thanks a lot for the help!
Page generated in 0.039709091186523 seconds with 17 queries,
spending 0.00843382 doing MySQL queries and 0.03127527 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
