diyAudio.com diyAudio Forums Archive > Top > Source > Digital
cdplayer transformer faulty - Click HERE for Original Thread
tone
hello ppl..pls help
my 5 years old sony cdplayer transformer got burn today..i been having problem in identifying the transformer voltage..it has multiple (7)output voltage..so far i manage to identify 4 only which is 10/0/10/0 the last 3..no luck..the last 3 is for the display unit..i will try to tell u how the pcb layout..here's goes..
1)T-->reversed diode-->neg cap(63v)-->Pin1(M5293)-->Pin3-->neg cap(50v)-->-32volt-->display.
2)T-->zener diode(reversed)-->T(1)=-32volt
-->display.
3)T-->display.
can someone help me pls..thanks in advance..
rgds
tone
MRehorst
A transformer is a bunch of wire wrapped around a steel core. The only thing that can go wrong with it is burning up (unless you somehow physically abuse it). The only thing that can make it burn up is to hit the input with too high voltage (like maybe lightning) or try to suck too much current out of it (like maybe a short on the load/circuit side).
If you simply replace the transformer, there is about a 99.999% chance that it will just burn up again.
You need to find the cause of the problem, correct it, then replace the transformer.
Most CD players aren't worth so much effort/expense.
MR
Page generated in 0.014719009399414 seconds with 16 queries,
spending 0.00549221 doing MySQL queries and 0.00922680 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
