diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
ZR1600 Problem - Click HERE for Original Thread
tomahack
I measured a stange signal on the right output of my ZR1600 at idle. Look like a sawtooth at around 675khz , 2.5 volts peak to peak. Any idea what could be the source of the problem?
djk
clock frequency.
tomahack
I know but is it normal that this signal is present at the output?
Evan Shultz
No, the clock should be attenuated by the output filter. The output filter could have died on you. Also, the speaker's impedance at that freq may mean that the clock won't be reproduced. It's best to remove it, however.
BTW, is this signal also present on the left channel. That would indicate whether you have a problem or not.
tomahack
I measured the signal at the tweeter end. There is a constant hiss but barely audible. 2.5 volts P.P on both channel
Page generated in 0.019484996795654 seconds with 16 queries,
spending 0.00688291 doing MySQL queries and 0.01260209 doing PHP things.
Please support our sponsor.
