diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
PDA amp - Click HERE for Original Thread
ebijma
I have a PDA with a route planner.
Volume of the PDA is much to low for listning while driving the car.
So i build a amp based on a TDA1815 with a small speaker.
The TDA is in bridged mode so the output should be close 24 watts at
12 volt.
Thats allot but i don't use it at full power.
So it doesn't get hot at all.
Works perfect.
But.........................
Do some of you know a filter that filters out the lows?
I only want to hear the frequenty thats been used by the vioce.
I want to filter the input this is at line level.
This is easier on the small speaker.
Hopefully some of you can help me out here.
theChris
look into resistor -- capacitor circuits. rc for short.
they will begin to block high or lows, depedning on the arrangement.
demogorgon
what you want is a highpass filter, possible a bandpass filter.
Knock yourself out!
-marius
ebijma
Thanks.
Didn't know it was that easy to find it on google.
But what frequenties should i use for voice?
demogorgon
well, the bandwith on house phones are 100hz to 3600hz if i remember correct, so you should not go much lower or higher than that, i would not at least..
G4ME
you also have to take into account what speaker you are using, i imagine that its a small full range, in a small box, that can't go to to low, so i would be conservative and say 200hz and nothing above 4K
ladaniva
Hello!
My message is for Ebijma. I am looking for a TDA 1815 record bias IC to fix my beloved Tascam 122.
Do you know where I can find one?
Please contact me at guilsimard"a"yahoo.fr
Thanks!
Page generated in 0.022396087646484 seconds with 17 queries,
spending 0.00765753 doing MySQL queries and 0.01473856 doing PHP things.
Please support our sponsor.
