| pocket tv lcd for a diy projector.. 2.2" - Click HERE for Original Thread |
| Tekko |
| If the LCD and tuner board is separate, could i have the tuner if you buy this ? I would like a tv tuner in my 6" LCD. |
| alapimba |
if i buy this? i have this with me..i was trying to find a use for it...
how can i know if the tunner board can be used for your 6" lcd? let me know. |
| Tekko |
| It should have a RGB and CSync output (the inputs on my lcd), could be just composite tho but i can use it either way, i have another lcd on the way that has composite input. |
| alapimba |
this is the inside.. i wont strip the tv more than this.. can you see something that help you?
| Tekko |
| Very hard to tell, i would need the datasheet for the tv with a block diagram and schematics for each board, the tuners circuit could continue on the lcd board. Atleast the control buttons are there. |
