diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
Show me your guts! - Click HERE for Original Thread
neurot
I am just starting to learn about car amps and would like to see what various manufacturers have done in terms of board layout, components, and general construction.
Well, I have an old Advent PA250 which is a 2x50W bridgeable amp. It uses one KTD718 NPN and one KTB688 PNP for each channel. Switching mosfets are IRFZ34 and the PWM generator is the TL494, which I am finding is a fairly common unit. The rectifier is two independent TO-220 chips which I can't find anything about. The package says 2502n and 2502c for the other. Each has an independent heatsink and is not connected to the main sink. There are two NJM4558 opamps sitting next to the bridge switch and input sensitivity pot, but I haven't looked at what they are doing yet. I don't know much about the transformer and don't have any test equipment around to check voltages.
The bottom of the board is full of thick traces with lots of solder on wach trace, which I assume increases current capacity. There are no plated vias, just holes, and the top of the board has jumper wires to the other side.
Like I said, I am still learning, and it would be nice to see what other amps look like, as I would eventually like to build one. If this takes off, I will go pull the punch 400x4 out of the truck and snap a few shots of it.
maxw
I love seeing the insides :devilr: I open pretty much everything that comes into my posession. Anyway.....
Here is a cheap audio-strada ASA-2150, 1x150WRMS when bridged, its a really cheap amp:
maxw
A phoenix Gold QX-4150
maxw
Close up of some of the QX4150
maxw
A Phoenix Gold Sapphire SA 3.0X, 4 ohm bridged @ 13.8 VDC - 300 WRMS x 1
maxw
And for good measure an Alpine 3900 DAC :D
profuse007
someone blew up this gut
power precision
PPI-2150M
i am a noob to amp... period!!!
switchers: IRfz34
________: 2n6487 and 2n6490
^^dont know what it is
and still a noob. broken amp
neurot
Wow, the layout on the QX4150 is nice. Is there any SMPS that does not use the IRFZ44 or 34?
Looks to me like the emitter resistor on the far right is cooked. Indicative of a shorted output device? Just a guess...
profuse007
yeah, i think
djQUAN
do diy car amps count?
www.djquan.angelcities.com/amplifiers2.html
also, two test reports showing insides of the amps.........
http://caraudiomag.com/testreports/0308cae_xtant/
http://caraudiomag.com/testreports/0311cae_trutech/
Tekko
I must say i always wanned a car amp to repair but i cannot drive them, no ps big enough. Heres a pic of a diy amp i meant for car use.
maxw
That Trutech one is a beauty!
Wima caps and BB opamps:
djQUAN
IR mosfets and machined connectors. all comes with an enormous price tag. :xeye:
spots25
ESX Q120.4
US Acousics 800F (Zed made)
Celestra-rules
Here is a beauty you don't see, check it out. AMAZING build and sound quality to compare only to high end home amps.
Celestra-rules
OPPS HERE IT IS
DookieFace
http://www.realmofexcursion.com/pics.html
tsmith1315
profuse007 wrote:
quote:
switchers: IRfz34
PPI used 2n648x/2n649x for the output transistors. The only mosfets were in the power supply.
Tim
BuzzerBro
I just got this PPI Tube Driver Amplifier. I am not sure if its a TD275, TD2150, or TD1250. Anyone know which it is?
Check out the pics here:
http://photos.yahoo.com/tariq_azhar
pgjoyride
some PG amps, will find a ZPA shot soon.
M100
pgjoyride
ms1000 (now this is a big amp)
pgjoyride
zx500, I will try to get some of the main board only. (as you can tell I dont know how to add multiple pics in one post.
pgjoyride
xenon 100.2
TO-3
Took me forever to figure out how to get this pic small enough to post. But finally, here it is.
Butler Audio Tube Driver BLUE: TDB2150 signed by BK, himself.
maxw
Niiice :devilr:
TO-3
Niiice :devilr:
Thanks. It sounds even better than it looks. Now if only I had a car to put it in............:bawling:
maxw
Feel free to put it in my car :D
TO-3
Hey man- I know it's not the 275, but it is silkscreened on the board somewhere. I didn't see it in any of your pics, and it's been a long time since I worked on those, so I don't remember where it is exactly. At least it has the DC protect(MK Savior) board on the bottom.
Tomg
I'm quite fond of my Sony XM-2000R:
does the job nicely :D
maxw
wow, thats a beautifull beast! especially for a Sony :cool:
Tomg
Isn't it just, it's damn heavy too, something like 27Kg!
sid216
sony make a quality car audio product... HA. wouldn't beleave it untill i've seen it... and i just think i did...
romen
quote:
The devil has been known to deceive those who are blind to it. ;)
Anyways, ill post my pics up on my car AMP soon... when the camera battery recharges
maxw
The internals removed from my Alpine 3558 'Class A' amp. More pics here:
http://www.diyaudio.com/forums/show...&threadid=59810
(I havent fixed it yet)
Dr. Fosgate
Phoenix Gold MS275
Phoenix Gold M25
Phoenix Gold M50
Phoenix Gold M44
Phoenix Gold ZX450v2
Phoenix Gold Xenon X200.4
Dr. Fosgate
Here are some more…
Rockford Fosgate Power T5002
Rockford Fosgate Power 750X
Rockford Fosgate Punch 400.4
Rockford Fosgate Punch 60ix
Rockford Fosgate Punch 100 DSM
Rockford Fosgate Punch 100ix DSM
Rockford Fosgate Punch 100x2 Transana
Rockford Fosgate Punch 4080 DSM
Dr. Fosgate
And the last of my stash…
Zapco Z100C2-SL
Exile X600.4
This is my Phoenix Gold MS1000TA, after I hand wound new transformers for it…
RCBandwidth
Thanks for those outstanding photos...
Dr. Fosgate
Just trying to do what ever I can to contribute.
There are more detailed photos of my amps here:
http://www.soundbuggy.com/Eric/Car%20Audio/index.html
Easyamp
geuss this one.
Dr. Fosgate
Looks like a PPI AM something or other. The one with the internally bridged outputs, so you have to run both channels separate. Maybe an AM2400 or something?
Dr. Fosgate
Here is my favorite PPI amp…
maxw
quote:
Originally posted by Easyamp
geuss this one.
Its a beauty. Is it a PPI?
Easyamp
I'm not sure? It was handed to me to repair and the owner is unsure. The amp has no stickers or numbers on it.
TO-3
[QUOTE]Originally posted by Dr. Fosgate
[B]Here is my favorite PPI amp…
Those are nice little amps. With the help of a 15VDC power supply, you can get that guy up to 75W x 4. I wish I could find some nice pictures of the PPI 2500F1.
2500F1 Audio Side
2500F1 Power Supply Side
TO-3
That's an old school PPI Amp. I think it is a 2150M. I know I fixed a bunch of those things when I worked there. What is wrong with it?
Dr. Fosgate
I think what is wrong with it, is it has hard wired cables on it!
:dead:
sr20dem0n
Arc Audio 2100cxl:
http://www.resnet.trinity.edu/areyn.../2100cxl_01.jpg
http://www.resnet.trinity.edu/areyn.../2100cxl_04.jpg
Linear Power 2.2hv:
http://www.resnet.trinity.edu/areynol1/audio/lp_01.jpg
http://www.resnet.trinity.edu/areynol1/audio/lp_03.jpg
....sitting next to an Avionixx 400.2:
http://www.resnet.trinity.edu/areynol1/audio/lp_04.jpg
http://www.resnet.trinity.edu/areynol1/audio/lp_05.jpg
Avionixx 800.2:
http://www.resnet.trinity.edu/areynol1/audio/amp_02.jpg
http://www.resnet.trinity.edu/areyn...dio/avi_800.jpg
I've also got a US Acoustics 4085 sitting here, but it's not worthy of posting.....god I hate that amp
Dr. Photon
does that ARC-AUDIO 2100CXL have any components mounted enderneath the circuit board (on the back side)? The design is very clean, almost barren. I can see all the required parts except for the emitter resistors (I'm assuming bipolar outputs, since there's some TP-220 devices, presumeably as drivers). I only see one resistor per channel. are the emitter resistors surface mount on the back of the board?
sr20dem0n
That's as far as I got in the "disassembly", so I'm not sure if there is more on the backside of the pcb. If it was sitting right here I would take it apart further and see, but it's installed in the car running my tweeters, so it's a bit of a hassle.
I do have a much larger version of the same picture if you'd like, not sure if that would help you at all though
Dr. Photon
I just find the lack of any large through-hole emitter resistors odd. Everything else looks like it's on the front of the circuit board though (and most car amps I've seen had everything on the front, save a few with predominantly through hole parts and single sided boards that had a few SMT resistors and caps on the bottom of the board).
oPossum
geuss this one.
That is a PPI 2300AM. I have one on the bench right now if you need any voltages or waveforms. You can find my hand drawn schematics of it here
Be aware that the power supply in the AM series is *not* PWM!
Matt@Nearfield
quote:
I'll have a check tomorrow (we're the UK distributors), but yes,they are bipolar .. some of Robert Zeff's finest - and boy do they have some grip :D
Tomg
ello Matt! Didn't know you ventured round these parts! :p
Matt@Nearfield
Wotcha Tom, I read more than write :)
winslow
I'll have a few pictures of some amp guts to go up soon.
ocool_15
quote:
Originally posted by spots25
ESX Q120.4
what does the second transformer do? I've seen 2 different transformers in several amps. I am guessing one for the preamp ect and one for the power amp or is the second one part of some filtering?
MOER
Visit us at www.zedaudio.com to see our new mobile amplifiers
Dr. Photon
the second transformer has two coils wound on it to regulate the supply rails. the ends of each coil are between the outputs of the rectifiers and the filter caps. This is a called a choke input or choke regulated supply ("swinging choke" if you're using heavey ones with tube amps!). the two coils are wound on the same core so that transformer action can balance the supplys and make them "equal but opposite. The same technique is used in PC power supplies.
Safe_Cracker
Pheonix Gold X1200.1
matjans
bump
Excalibur x200.4, a not-so-new one i got for $10. One set of transistors were blown. They were pretty hard to find but i've managed to order them. 2SB778 & 2SD998.
sid216
this here is a soundstream rubicon302... i got this for the special ultra low price on $0.00usd. im a very proud owner...
yes i know the pic is poopy... i need a better digi cam...
maxw
3 more amps I got the other day.....
Soundstream Class A 100 II:
Soundstream Reference 405 (5 channel):
Phoenix Gold MAC200 (Audiophile version of MS275?):
sid216
i love that amp... i almost got the 705s when they had them at fry's electronics (outpost.com) were i live... but i had this silly little thing called rent to pay... life stinks...
what do you do with all of these amps anyway? if i may ask?
maxw
The 705 is very nice!
I buy and sell car audio equipment just out of interest and keep somethings for my self, or just play with new stuff then on sell it. I think I will sell the ref 405 soon as I prefer to have a separate amp for subs ;)
sid216
here is my new acquisition...
on the right top is 2 irfz44n nexfet power mosfets http://kitsrus.com/pdf/irfz44n.pdf (pdf)
on the bottem right and left is 1each 2sd778 pnp and 1 each 2sd998 npn
http://www.bg-electronics.de/catalo...?products_id=28
http://www.bg-electronics.de/catalo...d80603dd7241158
the top left i can not id, the writing on them is very poor. but i paid $40usd for it and sofar for it sounds pretty good... its no old school ppi but ehh.
i also figure it puts out about 50watts of alright power...
sr20dem0n
I recently opened up my other amp (others posted earlier in this thread), here are a few pics:
http://www.resnet.trinity.edu/areyn...dio/zrs8_01.jpg
http://www.resnet.trinity.edu/areyn...dio/zrs8_04.jpg
http://www.resnet.trinity.edu/areyn...dio/zrs8_05.jpg
http://www.resnet.trinity.edu/areyn...dio/zrs8_12.jpg
http://www.resnet.trinity.edu/areyn...dio/zrs8_11.jpg
http://www.resnet.trinity.edu/areyn...dio/zrs8_06.jpg
http://www.resnet.trinity.edu/areyn...dio/zrs8_07.jpg
http://www.resnet.trinity.edu/areyn...dio/zrs8_09.jpg
That heatsink in the middle is huge, it easily accounts for most of the amp's weight. Barely gets luke warm to the touch when running at 1ohm. It's rated at 1500x1 @ 1ohm, and I have no doubt that it can do it.
ocool_15
quote:
Interesting design works well I would think. The power devices are all T0220? I guess the heat sink in the center would isolate the amp from the power supply also. The extra torroid(s) confuse me(under the fan) the 2 upper ones part of the power supply.
The lower one/caps by the connections I guess is some part of a regulated supply?
smaller ones on yellow torroids are part of filtering I think.
sr20dem0n
Forgot to mention what amp it was, in case no one picked it up from the logo on the heatsink and the pictures' filenames, it's a Cadence ZRS-8.
I didn't have a chance to see what type of output transistors were being used. Those black clips were on there very tight and I didn't feel comfortable brute forcing them off just to see what transistors were sitting underneath. I'm not sure about the torroids, I don't have much experience in amplifier design so your guess is as good as (read: better than) mine. It does have a regulated power supply though, so you might be right.
Safe_Cracker
Now that you guys mentioned the extra torroids, what are the ones to the left for? This amp is unregulated and those suckers get hot!
EnvisionAudio
Those are actually DC inductors which perform the function of filtering the HF content native to a switching type amplifier, namely the Class D.
Without those inductors, ~130V of 100kHz (pk-pk) hash would go into your woofers and throughout your speaker wires, causing havoc with yours and the neighborhood's radio reception.
The fan is an excellent addition - Cadence had problems with their inductors getting so hot that they unsoldered themselves from the board, initiating a shutdown.
Safe_Cracker
Ya, with the PG 1200, the whole bottom is a heatsink, I was so impressed by it ability to stay cool, even running @ 1ohm. Polo..:)
ocool_15
so there just in series with each supply rail and act like a lowpass crossover? Lot of wire but I dont know as much about this class D but makes sense. Just thought the voltage drop would be too signifigant (Re of coils ect) for it to be effective.
EnvisionAudio
No, they're in a configuration with two capacitors to form a second order L-C filter in series with the speaker output connection.
Like this:
Courtesy Maxim Integrated Products, Inc.
djQUAN
hmmm. do I see kapton tape used for TO-220 insulation for the cadence amp???:cool:
sid216
that visonik amp pics i posted... that is the crappiest amp i have ever heard... i think the sparkomatic bass cannon has more impact tham this thing hooked up to anything.
marko
hi maxw, what is differance between these 2 amps? i know the power differances but want to know more! i own several ms275's and ms2125's too!
maxw
quote:
Hey Marko,
I'm not really sure. The AC stands for "audiophile class" and in its specs it has lower distortion and high S/N ratio so I guess maybe it just has better matched components inside or something like higher tolerences. I dont have a regular MS275 to compare it to. I'm gonna sell it now anyway as I have a Digital Designs amp to drive my sub ;)
ocool_15
If the s/n ratio is better and the distortion I would suspect the semiconductors used were of better quality the the standard ones. Like the op amps in the preamp. perhaps the power supply had better filtering/less noise.
denis59
Hi ! I'm french, so I hope you'll excuse my english :angel:
We purpose to me a Phoenix Gold MAC 200, so I don't know this amp and I like to know if it's a good amplifier to plug with a MB Quart PSD 213 component.
I'm looking for quality, both dynamic and clearness.
Is this a good amp for this use ?
Thanks a lot ;)
PS : I've mailed Phoenix Gold to know the difference between a MAC 200 and a MS, that's their answer :
"The amp is a great unit and will function well for almost any moderate power purpose. I do not have a manual for the amplifier that I can provide you but if you look a the dimensions of the unit and compare it to the same size “MS” chassis amp, it is the same unit with a different power supply. The power supply in the “MAC” is optimized for 8 ohms vs. the 4 ohm rating of the “MS” so the 4 ohm rating of the MS amplifiers would be the same for the MAC except at 8 ohms instead."
maxw
Thanks a lot ;)
Interesting answer they gave you denis. I love it how PG are so honest, its great!
Here is the manual for this amp:
ftp://208.187.38.55/Phoenix_Gold/Ma...rs/MS_MAC_Amps/
and yes I think it would be good for those MBQ components ;)
denis59
quote:
Phoenix Gold support
The power supply in the “MAC” is optimized for 8 ohms vs. the 4 ohm rating of the “MS” so the 4 ohm rating of the MS amplifiers would be the same for the MAC except at 8 ohms instead." [/B]
Is it important ? What's difference between 8 ohms and 4 ohms power supply ?
maxw
Its important but it will be fine for your speakers which are 4 ohms. You cant bridge it into 4ohms or use it as 2 ohm stereo ;)
ronnsull
I was wondering if anyone had the schematics availible for a Phoenix Gold M50.
hc_TK
http://ampguts.realmofexcursion.com/
I think you would love this page! over 1000 different amplifier internals! ENJOY!
Ocelaris
Here is the amp I am currently working on... an a/d/s/ P640, 6x40 or 2x120 and 2x40
Motorola 1302a and 3281A to-247 output transistors, 8xNDP7060 Power supply FETs, bandpass and high pass active crossover network built in...
perfect for a 2-way active setup, bridge channels 1+2 and 3+4 for mids, and use 5 and 6 for tweets.
ROBJETS
I have an M44 PHoenix Gold that I was working on and while I was un sodering a bad resistor I accidently ripped a trace on the left side of the resistor to the right on the picture shown.If someone could post a better close up of the area it would help me greatly because I cant find where the trace origianlly went.I was using a battery operated board sodering iron and apparently it wasnt hot enough.I have searched and search and havent found any good closeups of this board.This is still my favorite amp even though I have newer ones.
ROBJETS
What I need is a closeup right in front of the two big blue capacitors.In front of the right one to be exact.None of the closeups for M44`s I found didnt show this area.
Page generated in 0.18254804611206 seconds with 17 queries,
spending 0.01125860 doing MySQL queries and 0.17128944 doing PHP things.
Please support our sponsor.
