diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
virtual ground...help - Click HERE for Original Thread
jsteigs
well, how do you make one? i want to know so that i can run a 5532 and similar op amps off a single 9V battery.
steigs
joensd
here´s two possibilities to do it.
http://sound.westhost.com/project43.htm
Something like a BUF634 is another though more expensive solution.
I´ve used it to split rails of a 30V wallwart and it worked out really nice. Besides the BUF634 has only about 1.5mA quiescent current in low-bandwidth-mode which is keeps your batteries happy.
Have a look at the datasheet especially where it says "pseudo-ground driver".
greets
pinkmouse
If you could stretch to 2x9v batteries it would improve the headroom no end, and make the earth easier, just run it from between the two batteries.
azira
It would be simpler and extend your battery life if you used coupling caps.
Danny
jsteigs
quote:
The point is that I don't want to have to use 2 batteries...
btw, thanks for the ESP website joansd
setmenu
Plenty of useful info here:
http://tangentsoft.net/elec/vgrounds.html
Setmenu
Yoghourt
Have you considered biasing your opamp schematic?
Page generated in 0.035115003585815 seconds with 17 queries,
spending 0.01521373 doing MySQL queries and 0.01990128 doing PHP things.
Please support our sponsor.
