| JBuzenberg |
| A car with stock, active speakers (each has a dedicated clarion amp) also has an amplifier in the aftermarket Alpine car stereo (50 x 4). Result: the signal is amplified twice and so the volume knob is much too sensitive--three clicks away from zero and it's already too loud. (A) Is there a way to use the sub-woofer output on the head unit to send a non-amplified signal to the car speakers? Or, (B) should I just forget using the clarion amps of which there are four and rely on the amplifier in the head unit? If (A) is possible, then would it also be possible to use the car stereo amplifier to power a subwoofer, since the speakers are being run by their own amps? Any help solving this dilemma is appreciated. |
| arcom |
If your car stereo has preamp outputs for front/right channels, connect them to the inputs of your Clarion speaker amps. If not, you can put a resistor (say, 100K) between the car stereo's outputs and amplifier inputs.
Running a sub from car stereo is not a good idea because of its low power (those 50W are actually around 20W RMS, if not even lower) and you can ruin either your sub or car stereo or even both.
Hope this helps. |
