diyAudio.com diyAudio Forums Archive > Top > The Moving Image > General Video
DVD HACKS (not region hacks : ) ) - Click HERE for Original Thread
magic_mat
Hi all
I have a farly new dvd player but the other week it died. I check every thing even the fuses and stuff inside! So i took out all the boards and stuff. Is there any thing i could do with the drive or board with all the video and audio conectors? Wire it up to a hard drive or something? (were you can play mpegs and pics on your tv , it has been done!)
Is there anything i can do with it?
Thanks alot
Matthew
TheGiver
I believe that would only work with the old Apex DVD players that used standard IDE DVD drives. Wouldn't it be a pain to swap the drive out everytime you wanted to put a new video on it though?
karma
what about a pull out drive?
magic_mat
what make and model player could i get that still be around or on ebay that uses an ide interface?
As long as it supports IDE could it bepossibleto add a hard drive?
I could make the HDD also external so you could plug a usb in to the player.
I have seen this done( a whole site about it) but icant find that type of player! Is there any i could look for ?I am in the UK.
UrSv
Most cheap players use IDE but it is the software and hardware that makes it possible to run a harddrive instead of a DVD drive.
In most cases for a standard cheap DVD player it is NOT possible to make it work with a harddrive.
Players like KiSS, Sigmatek and many more support harddrives in the right version.
Page generated in 0.019431114196777 seconds with 16 queries,
spending 0.00758100 doing MySQL queries and 0.01185012 doing PHP things.
