diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Data/pinout on STK407-250 - Click HERE for Original Thread
Tekko
Hello! Does anyone have a datasheet or pinout on the STK407-250 ? I searched google last night and gound nothing.
Tekko
I did find one but i need to pay for membership to get it. I need the pinout for STK407-050 and STK407-250. If anyone have a datasheet or pinout or atlest know where to get it or can get it for me, please shoot me a message on my email or msn messenger if i´m online or just simply answer on this thread.
Netlist
Why not e-mail Sanyo?
/Hugo :)
Franz G
Here we are :cool:
I got 3 CD's with Harman Kardon service manuals and will find out a circuit, using this chips.
Later, I will post the circuit, to give you more info.
Franz
Franz G
Sorry, the GIF is not readable.
Here the text:
STK407-050
1 CHAN 2 -Vcc
2 Chan 1 -Vcc
3 Chan 1,2 +Vcc
4 and 5 Thermal Sensor
6 Chan 1 Out
7 Chan 2 Out
8 Pre -Vcc
9 Pre +Vcc
10 Chan 1 +Input
11 Chan 1 - Input
12 C.C.C. Bias
13 Chan 2 - Input
14 Chan 2 + Input
15 Ground
STK 407-250
1 Ground
2 N.C.
3. Chan 2 -Vcc
4 Chan 1 -Vcc
5 Chan 1,2,3 +Vcc
6 and 7 Thermal Sensor
8 Chan 1 Out
9 Chan 2 Out
10 Pre -Vcc
11 Pre +Vcc
12 Chan 1 + Input
13 Chan1 - Input
14 C.C.C. Bias
15 Chan 2 - Input
16 Chan 2 + Input
17 Chan 3 - Input
18 Chan 3 + Input
19 Chan 3 -Vcc
20 Chan 3 Output
Hope, this helps!
Franz
kolbasNIC
This is 2
kolbasNIC
I have a block-diagram STK407-050. File is 102k. My e-male: perebaskin@yandex.ru. You need this file? Send me letter.
florin01
What does the "250" stands for? is the STK407-350 similar with the STK407-710 (STK407-710k) ??:att'n: :att'n:
Does one of them have a slight more power or uses a higher power suplly?
Does some one have a datasheet for STK407-710?
:cheers:
kolbasNIC
Greetings!
STK407-710K - 100 W min audio power amplifier class H, two-channel, THD = 0.08%, RL = 4 to 8 Ohm, built-in posistor, MOSFET switch.
There is a unchecked information, that STK407-710K = STK411-200K (it is possible to replace any STK411-2xxK). The case at them identical. The pinout similar too. The suffix K means the MOSFET switch.
If the information is necessary still - write in å-mail.
florin01
thank you :cloud9:
wow 100W :bigeyes: :cheerful: :worship:
I can wait to make it wok
thanks again:cheers: :cheers:
Page generated in 0.030232906341553 seconds with 17 queries,
spending 0.01162076 doing MySQL queries and 0.01861215 doing PHP things.
