diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
non-inverted tone control? - Click HERE for Original Thread
otaku
Hi, diy community people,
I have an old crown preamp based on 70's op-amps and looking at its schematic, noticed one thing strange.
schematic
It uses one single channel op-amp for each channel in non-inverted configuration, and it has tone control feature. As far as my limited experience tells me, I've never seen tone control circuit in this configuration, which amazes me a bit. All circuits I saw had inverted tone control then another inverted unity gain for phase correction..
Perhaps the engineer of this unit wanted to minimize the number of op-amps by non-inverted tone control followed by no 2nd stage. Is it considered a good technique, I wonder?
I'm also feeling this preamp sounds very dry. Basically it has no gain throughout the circuit which makes it sound dull, I suppose? There's a switch I can select 0db and -10db. At 0db, I could hear noticeable noise. Replacing with OPA627 didn't help.
Any suggestion for possible mod and opinions on the circuit design will be truly grateful. Thanks,
Page generated in 0.015753030776978 seconds with 17 queries,
spending 0.00728416 doing MySQL queries and 0.00846887 doing PHP things.
