diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
laptop lcd - Click HERE for Original Thread
orgazmosis
can you use laptop lcd panel as replacement for lcd pc monitors i noticed many cross reference numbers mach are they the same connectors from lcd to control board????????????????:confused:
will1384
Some times a laptop lcd panel can be used to replace
a broken desktop LCD panel - but you need the LCD
controller to feed video to the lcd panel
And even if it works it may not work 100% you may miss
some resolutions or refresh rates
But If it has the same part number than it should work
on a desktop lcd monitor or laptop just fine
Page generated in 0.016813993453979 seconds with 16 queries,
spending 0.00823402 doing MySQL queries and 0.00857997 doing PHP things.
Please support our sponsor.
