diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
13v on 2 12v fans - Click HERE for Original Thread
part2wanksta
i have a 120mm fan and a 80 mm fan connected together and i wanna hook them up to a 13v adapter.
will the extra 1 volt mess anything up. or will i be okay
Duo
13V will be fine on those box fans.
lol, I have an array of them running at 24V which is about as hard as I've been able to run them for extended periods of time. ;)
ace3000_1
You might wana watch that. Anyone of those coils burn out in those fans and you got a fire.
Most 12v fans are rated to 13.8v or 14.5v.
Trev:)
part2wanksta
yeah maybe i will go up to 24v. i was using 1 12v adapter on 5 fans. and they didnt seem to do much.
so now i am going to use 3 adapters.
13v 80mm and 120mm
12v 80mm and 120mm
12v 80mm
can i go with a 30v and power them all
Duo
Well, firstly, yes, I did understand that over heated coils = fire. I'm living with the fact that this may occur and i'm fine with it. They're just a lot of old cheap used computer fans.
In an application where you need the fan to cool something, I wouldn't recommend running it over 15V. It's risky if you're cooling a light fixture or something like that.
If the one 12V adapter didn't run the five fans, that means it didn't have enough current ouput capability. A power supply must deliver more current to heavier loads but at the same voltage.
ace3000_1
Most 80mm fans draw 150ma max at 12v.
So 5x 150ma = 750ma.
All you would need is 1 power supply that has a rating of 12v @ 1amp and your set.
Trev:)
ace3000_1
Wheather its cooling somthing or not its gonna burn out, its like running a 120v lamp on 240v!!!
If they dont spin fast enough at 12v, get ones that do.
Trev:)
nick[x1]
They were designed to run at or around 12v so thats what they should be run at really. Just get a decent PSU with a bit of power behind it to provide the power to all fans at 12v :) my 5A 12psu is great
Guy Grotke
You could run two identical 12 volt fans in series from a 24 volt power supply. Or pairs of those series-wired fans, wired in parallel to the 24 volt PS. Or you can just save yourself the hassle and get fans that match your power mains: 120 or 240 VAC.
Since my LCD came with its own power supply, I just used a 120 VAC fan. So I don't have any need for an additional power supply. This only comes up if you are using a 12 volt LCD (designed for a car) that did not also come with a power mains adapter. Or maybe if you are trying to build a projector for your car!!! :D
part2wanksta
well i used my 13v adapter. it was rated at 0.8a so it was good enough to power them all. my lcd doesnt even get warm.
im so happy. lol
Page generated in 0.039781093597412 seconds with 17 queries,
spending 0.01693845 doing MySQL queries and 0.02284265 doing PHP things.
Please support our sponsor.
