diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
High quality amp with 2sk1530 and 2sj21 - Click HERE for Original Thread
Bensen
High there,
Does anyone know a good amp (circuit) using the 2sk1530 and 2sj201 devices. Because these are the only devices I can buy which are already matched.
I build the original Crecendo amp (1982) with the 2sk135 and 2sj50 (TO3) devices. I used devices that aren't matched, but it still runt very good after 7years.:)
I want a bit more quality and power (140W/8ohm).
I have also made the Crescendo ME with the newer devices, I use that amp as plate amp in a sub.
Another option is working with one P and N device, but than I probably can't run 4ohm loads with high power.
Thanks in advance
Ben
ACD
You can build any amp you like, as I don't think there is a special design to fit only the 2SK1530/2SJ201 ;)
Have a look in the forum on all the interesting projects and amps, and pick one :D
Page generated in 0.015785932540894 seconds with 16 queries,
spending 0.00748110 doing MySQL queries and 0.00830483 doing PHP things.
Please support our sponsor.
