diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Musical Instruments
60 Hz band reject filter - Click HERE for Original Thread
rabstg
Hi All-
I did a search and got zip.. So here goes.
Has anyone ever tried a band reject filter to deal with 60 Hz hum from single coil guitar pickups?
I am NOT a musician, but I rewired my neighbor’s guitar and made it dead quiet. So quiet that it picks up the ticks of his watches second hand on his left wrist.
He loved the silence of the guitar but I was still appalled at the hum it picks up.
I will be trying the out steel shielding cups behind the pickups, but I curious to see if anyone had ever tried an electrical solution.
Any inputs welcome!
Optical
perhaps have a look at this circuit?
http://members.shaw.ca/roma/nine.html
not sure if its what you are looking for..
what did you do to the guitar to make it 'dead quiet'?
jackinnj
Texas Instruments has a 60Hz notch filter right on their website -- in the opamp applications area.
rabstg
quote:
First of all I twisted the pick-up coil leads... Instead of them separated and laying all over inside. I think that was most likely the biggest single improvement.
But then I screened the twisted pairs from all three pick-ups (Strat) and grounded to the pick-up switch. Then I used shielded twisted pair wire to connect the switch to the pots and from the pots out to the jack. ALL wire was Silver plated Copper with Teflon insulation. I use it on other projects and had it handy.
Worked well. Picture attached. Before then after.
As for the 60 Hz band reject, I was thinking more on the lines of passive components and making a tank circuit.... I just don't know if it is practical at such a low frequency... The components may have to be too large due to the frequency extreme even though the signal level is miniscule.
rabstg
After. Not perfect but really helped out.
Nasse
I think 120Hz (100 Hz in europe) harmonic (and maybe others further up) is what you really hear mostly with some guitar speakers
I think I have seen old article suggesting putting 50 Hz and 100 Hz filters in series
Enzo
SIngle coils pick up environmental hum. That is why humbuckers were invented. But humbuckers sound different. As far as I know, there are no silent single coils.
You start hanging filters and circuits all over the guitar input, and you pretty quickly lose its tone.
Might as well use active pickups. Check them out.
You might go over to Seymour DUncan's website for pickup info.
There is a pickup winders forum over at www.ampage.org, but I fon't frequent that room there. All the other forums there are very knowledgable, so I expect this one to be.
rabstg
quote:
Hi-
This is going to turn into a project with LOTS of testing!.. Long late hours of drinking beer and listening to my buddy play his guitar to ensure my mods don't infrenge on his tone...
Rough job but somebody has to do it...
I'll start by checking if the offending hum is the second harmonic or the primary 60 cycle pwr.
Then I will calculate some values for the appropriate filter.
Around then it should be time for a beer.
I'll let you know how far I get.... :-)
phase_accurate
Another solution to picking up hum is the use of a compensation coil like the one that Alembic uses on their basses. In this case one can still use single-coil pickups. But that approach would require quite some effort.
Charles
BbbyBld
As a guitar player, I would be wary about that kind of filtering! Maybe the easiest thing would be to get a noise gate.
argonrepublic
The only pickups that are noise free are active. I use EMG in all of my studio Guitars. The fender Lace sensor can be aquired pretty cheap on ebay. They are a shieled single coil. My guitars are in a pretty EMF and RF intense environment. EMG sa re all that will work here.
Page generated in 0.033863067626953 seconds with 17 queries,
spending 0.00916433 doing MySQL queries and 0.02469873 doing PHP things.
