diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
Some help.. Projected image distorted. - Click HERE for Original Thread
The Alchemist
I got a lightbook (proxima) lb 20. It has a single display (6.4"). It was defective but after replacement of a transitor i got an image. The problem is dat it is distorted. Too mutch red. I reseted to factory setting but that didn't help. What could it be? The cable is good. I connected via S-VHS and composite.
Pic's:
Comparison picture.
davemcmahon
Check everything in manual check connections etc use with different source (for example this might be a source component prob) also if pos use a different cable (type)
P.s you might be stuck with the unit as you've opened it
Page generated in 0.052401065826416 seconds with 17 queries,
spending 0.00746799 doing MySQL queries and 0.04493308 doing PHP things.
Please support our sponsor.
