| jeff2747 |
Due to a change of plans I'm selling this populated and tested P68 board. Initial test with +/- 12V carried out only. Sounds good even with this low voltage. It was a fairly short test due to no heatsink.
The board is from Elliott Sound Products.
Seen here... http://www3.telus.net/public/jeff_e/p68.htm
Parts used
-MJL21193/94 outputs
-Mills non-inductive 5W current sharing resistors
-panasonic FC electrolytics (except input bipolar cap)
-silver mica caps for C3 and C6
-yageo metal film 1/4W and metal oxide 1W resistors
Pcb pins are installed, heatsink for driver transistors is the recommended 2.5" by 1", no insulators are included for power transistors
I would like to get $100 Cdn. This is what the parts cost alone, not including shipping from digikey, partsconnexion.com and ESP.
Shipping for this would be $4-5 in Canada or the U.S.
My ebay id is aero-jeff
Thanks,
Jeff |
