diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Loudspeakers
good or bad idea -- monacor SPH-165KEP - Click HERE for Original Thread
qubix
Hi !
I have heard many good things about this unit and think about using it in my next project.
How good is it really? To which mid-woofs in terms of sound quality would you compare it?
I've got a pair of sale out SS 9300 comming up. Is it a good idea to team them up with the monacors?
Another thing. The XO point would be at around 2 - 2.2 kHz, and i would like to get the baffle step correction done somehow. Either by making a 2.5 way or only on XO by lowering overal efficiency. What would you do? a regular 2way with BS correction, 2,5 way or MTM with BS correction?
Thanks !
bombardon73
These monacors are really good, for this price you can't get a better 6,5" unit. When compared to the expensive ScanSpeak units they only have a bit more k3 distortion (but still under 0,8%).
Frequency linearity and the cumulative spectral decay is as fast as these ScanSpeaks. Also the monacor is easier to Xover, it has a really smooth drop-off at the highend.
When xover at aprox. 2,2 khz you may only need to increase the value of the inductor in series with the 165kep to compensate for the bafflestep.
I'm sure that when used correctly you'll get superb results!
btw, I would go for the MTM version because you'll get better efficiency that way, and the d'appolito version will have very solid imaging.
qubix
thanks for an answer !
MTM was my preference also. There is a project based on that idea using seas noferro somewhere in the net.
You mean that this monacor can be compared to same size SS woofers? But it costs here in Poland 3-4 times less than the ScanSpeaks!!!
Anyone else has some experiences?
Nemophyle
hello
i bought two monacor SPH-165KEP; i didn't used them for the moment as i need to finish a pair of speakers before beginning to build my owns.although, i made them run in free air and their medium is OUTSTANDING, really, without any filter i couldn't hear any ringing resonnance and the sound was perfect, i hesitated to keep them for using them as mediums for an open baffle project.
although, given the specs, the bass with one of theses things will be slow ,and they have pretty low efficiency (this is predictable given the fact that they go down to 45hz in a 15 liters BR cabinet, pretty good for a 6.5" driver)...
given this fact, if you have the money (i don't :bawling: )go for an MTM. if you look for the FR of the monacor,if i'm not dumb, and depending of the size of your baffle, you may not need Baffle step compensation, because the SPL level is slowly decreasing as frequency rises.
i wouldn't Xover this driver at 2.2, moreover if you gonna cross with a passive XO as it haves outstanding mediums and 2.2 khz is a pretty critical frequency. 3khz would be much better i think, but i dont know the off axis FR may be more critical in such a design
Asdonk
I also have plans to build a MTM with the sph-165 kep and the
mtm on the web can be found at
www.cuvac.de/allerlei/leopard.pdf
it is a dŽappolito with serial filter:clown:
qubix
yeah -- leopard was the thing i've digged up also.
I would decide on the XO point when i'll buy and measure myself the drivers - i've got a SW rig. I recon 3kHz would be just to high because the off-axis FR. But... we'll see. 3kHz XO point would also cry for a 19mm dome that should move faster and more agile than the 25mm. Also i'm not sure if it's not too high for a d'A MTM we're thinking of here...
Maybe someone did measure them and can comment on that.
armonrib
I also have made a testmule with a 165 KEP on a cardboard open baffle, I have combined it with a Philips RSQ8P. As a test I am using a 6db crossover for the tweeter and no crossover for the Monacor. The combination sounds amazing. It needs a lot of eq to be balanced in the low end. I 'll make some measurements soon
Mikael Abdellah
I have used a SPH-135KEP with a DT-101SK with my tubeamp for almost 2 years now. The sound is amazingly clear and open.
Leeuwarden
I have a (from top to bottum) Hivi RT2C, SPH135KEP and two SPH165KEP design in the workshop at the moment Already playing is a combination of the SPH165KEP en de HiVi. Sounds great!
markp
Who sells Monacor in the U.S.?
Leeuwarden
Nobody? (I think)
bombardon73
Is there really no export to the U.S.?
Thats a shame, I use monacor speakers a lot!
They have some superb units like the 165kep with High-End alure for a very resonable price. They are cheaper because there's a BIG manufacturer behind it, so don't get fooled by is price tag.
If their price was twice as high they would probably be in the high-end scene.
I made some 2-way monitors for a studio wich have the 200ke in it, this puppy goes LOW. Only 32 liters for an 8" chassis reaching 38hz -3db (with passive radiator tuned very low).
The mids of the 200ke are also fenomenal, I never heard an 8" unit handle mids that good. The highs are taken over by the infamous dayton magnetostat XO at 2khz, yup, 2khz. Am I mad? No, when using the right XOnetwork these magnetostats sound superb! Everyone who heard these speakers were stunned by it's imaging and flawlessly unmasking every detail in the recording. There is allready another studio who wants the same speakers!
uli
MTM SPH165KEP DT25Ti
Uli
:nod: :nod: :nod:
uli
MTM SPH165KEP DT25Ti #2
Uli
:nod: :nod: :nod:
bombardon73
looking mighty impressive Uli, the Dt25Ti has also been tested in a german magazine. Very flat response and even at 30khz no breakup, thats superb for a titanium 1" dome.
That same magazine used the DT25TI and the sph-170 in a TL-line. It was supposed to be a "cheap-trick", but in the end they gave the box golden connectors because it deserved it!
Another proof for Monacor producing great units at a fair price.
bombardon73
Also check this link http://ldsg.snippets.org/vendors/monacor.php3
Asdonk
hello Uli
very nice speakers, do you have any schematics off the crossover
for the mtm monacor sph-165kep and 250Ti
if so can you mail them to me or put them on the forum
uli
Hi Ralf,
I have to draw them first, then I will post it.
Uli
:nod: :nod: :nod:
Tomac
Nice speaker. Which bass drivers are those?
uli
10" SPH255 tweaked with ferrofluid, added 10g mass to membrane.
12" SPH315 original.
Note that the SPH 165 are ff tweaked too.
Uli
:nod: :nod: :nod:
Tomac
I only know of sph-265 not sph-255
Is it an older model?
What kind of box is it? Vented?
Do you have any measurements?
uli
Measurements are not available, I did them without computer.
(old Neutrik measurement system)
SPH-255
Uli
:nod: :nod: :nod:
PS: vented, box is tuned to 25Hz
kestrel200
Ok! Now you have my interest! How much would it cost me to have one of you to get me four SPH165KEPs and ship them to the US? I could I talk you into it? If they're that great maybe I'll become their rep in the U.S. !!!!
Thx!!
Leeuwarden
I think you can order them here. It's a Dutch company which also ships abroad: http://www.bmm-electronics.nl/intro.asp
Tomac
price for a single unit is 72 euros as far as I know ,maybe it varies 5% up or down
don't know how much would shipping to USA be
qubix
Ok. I see that u ppl are quite happy of having those speakers. Are there any disadvantages or application difficuliuties of that speaker?
Uli: can you describe your XO? What are the critical frequencies, what difficulties did u have designing it, what types of compensation networks does it consist of?
Leeuwarden
Yes Uli, please tell us more about your speakers!
How did you tweak the SPH-165KEP?
uli
I filled the airgap with ferrofluid and dampened the chassis
on the back with bitumen stripes.
Xover is a 3way serial split into two parts to fit in the enclosure.
This way it is possible to use the satellites alone too (without
RLC snubber circuit!)
Uli
:nod: :nod: :nod:
Asdonk
hello Uli
what is the crossover frequencies between satelite
with the 2 sph165kep and tweeter and the woofers
uli
about 180 Hz
Uli
:nod: :nod: :nod:
Edit: tweeters about 2,7kHz and over 8kHz
qubix
OMG that is soooome XO :D
uli
"small" part in bass enclosure, old pic, not finished yet
Uli
:nod: :nod: :nod:
qubix
Is that speaker's basket made of metal or plastic ?
uli
Its made of stamped steel, not cast. Thats one weak point of this
speaker, but cast metal baskets are a price issue. To dampen
the legs of the basket is a big improvement IMHO.
Uli
:nod: :nod: :nod:
Leeuwarden
SPH-165KEP is not stamped steel...
Or am I missing something?
uli
You are right, just the 2 woofers are stamped.
Nevertheless dampening with bitumen is a good tweak.
Uli
:nod: :nod: :nod:
Page generated in 0.059652090072632 seconds with 17 queries,
spending 0.00968575 doing MySQL queries and 0.04996634 doing PHP things.
Please support our sponsor.
