diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
sony xplod - Click HERE for Original Thread
Michael mo
i have two sony xplod 250w 2/1 channel amps. i bridged them together and ran 1 amp to a pioneer 12" sub and the other amp to the other sub. the subs take 450 a piece.is that enough? or too much? i hooked them up through the left and right speaker on my radio because my radio only has one set of rca's coming out. should i cut those ends off and sodder the two rca's together and run them to the amps or just do like i have and use the high level input connection
sdoom
If you have RCA outputs , you should use them.
Check the Sony users manual if you really need both input jacks at each amplifier (because you use the amplifier in bridged mode , some amps require just one input jack if they are used in bridged mode).
If youŽd need both input jacks on each amplifier then run a normal RCA-cable to the amplifiers and use 2 Y-adapters .
Page generated in 0.016618967056274 seconds with 17 queries,
spending 0.00620317 doing MySQL queries and 0.01041579 doing PHP things.
Copyright ©1999-2009 diyAudio.com
