diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
McIntosh 5100 - worth restoration? - Click HERE for Original Thread
mjarve
Not exactly DIY, unless you count DIY restoration, but I have an opportunity to get a McIntosh 5100 integrated amp in non-working condition in direct exchange for a harman/kardon 930 receiver in perfect working order. As they say, a bird in the hand is worth two in the bush, but this may be my only chance to get a piece of Mac gear, unless by some strange fortune I win the lottery.
The problem with the Mac is that it outputs 27VDC at the speaker terminal, cooking speakers. I am thinking that a driver or output transistor is bad, or if it capacitor coupled (would it be?) the output cap for that channel may have shorted. I have not seen the amp yet, and the person who owns it right now is not very technically inclined.
So my first question is this: Is a h/k 930 a fair exchange for a Mac 5100? The little research I performed indicated that it would be, as at least on paper, the amps are very comparable, and the 930 actually had a higher retail price than the 5100 (1973 and 1972 respectively). The 5100 has a higher book value now though.
My second question is: Are McIntosh components, in particular the 5100, fairly easy to service (parts still available, etc.) or is it a money pit? I even heard one rumor that I could send it to McIntosh Labs for repair, costing me only shipping one way, although the Mac site does not bare that out.
anatech
Hi mjarve,
McIntosh, last I checked, still fully supported their products. There may be some substitutions needed, by the unit should be repairable.
Is this the MA 5100, 45 W/Ch ?
If this is both channels, check the 115VDC bias for the differential pairs. This is not a full rail output, so you don't have a classic shorted output situation. Also, it isn't blowing fuses. This suggests the output stages are okay.
I'd say, go for it. -Chris
mjarve
Indeed, it is the 45WPC SS version. The current owner indicated, oddly enough, that it sounds fine despite the fact that it will blow the speaker.
I'm going for it. I just know that if I do not, I'll regret it forever. Besides, I have two more 930's tha could use some attention as well.
anatech
Hi Mike,
Good choice. I've rebuilt lots of 930's. The Mac is worthwhile. It is repairable and it's not transformer output.:D
-Chris
Page generated in 0.019609928131104 seconds with 16 queries,
spending 0.00611329 doing MySQL queries and 0.01349664 doing PHP things.
