diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Mark Levinson No 27 Problem - Click HERE for Original Thread
johnsciolino
I am having intermittant problem with a No27 Levinson.
Breaker trips on front and emits a buzz in speaker on one channel.
However, if I ramp up with variac to 50v one channel has alot of DC offset (300mv) and after about a minute it drops to 10mv. At that time I can continue to ramp voltage up to 120v without tripping breaker. The amp plays fine after doing this startup procedure. When power is removed it goes back to the same problem on restart.
Could this be a bad cap? Its difficult to trace because using the variac seems to temporarily cure the problem before I can start troubleshooting.
LBHajdu
Do you happen to know how this amp handles inrush current limiting, it sounds like the inrush limiter may not be working. I would suspect they use a triac, however I have never seen the schematic of this amp.
johnsciolino
Files too big to post so heres the temp link to download.
Just got Madrigal to email these to me today.
http://www.munsonandbryan.com/downl..._schematics.pdf
http://www.munsonandbryan.com/downl...ofOperation.pdf
http://www.munsonandbryan.com/downl...t_procedure.PDF
johnsciolino
OK,
Got the schematics and bypassed the relay.
Its a short somewhere in the input. With the unit bypassed I get rail voltage at speaker output at full voltage but
its not blowing rail fuses probably due to the open circuit at speakers.
remi
Hello johnsciolino
Someone has asked me to mend their ML27, so that I am looking for the ML27 schematics.
That links site doesn't have it. Can you send it to me?
If you can help me I really thank.
My E-mail remi_gao@126.com
Remi
Page generated in 0.073712110519409 seconds with 17 queries,
spending 0.01309848 doing MySQL queries and 0.06061363 doing PHP things.
