diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
Mayware Formula 4 Uni-Pivot arm - Click HERE for Original Thread
peted
Hi all,
I have an old (20yrs plus) Mayware Formula 4 uni-pivot fluid damped arm I want to resurrect that is said to be a pretty nifty little number. My sample is in good condition. Either way it's a cute and attactive unit, just begging to be played with! I have the damping fluid already sourced. These babies were built in the UK and Australia - mine is the latter. I bounced this question off Allen Wright previously - he mentioned JH as the manufacturer, presumably confirming the Ausi connection.
So I need ideas for suitable cartridges please folks. Denon 304 and the 103 have been suggested. 103 difficult to obtain apparently now. I have a number of proven tweaks also for this arm. Am intending to fit to some as yet undefined self built deck - perhaps an Origin Live kit.
I have no MC i/p - so we are talking MM or hi o/p MC - but can beggers be choosers?
The spec for the arm is as follows: Can anyone translate that effective mass figure to matching cartridge compliance figure? Help me out here - hi compliance means what sort of figure? and lo comliance ...
SPECIFICATIONS (cut from UK version set-up manaual)
Effective length (stylus pivot): 224 mm
Rear overhang required: 65 mm
Height adjustment: 45 mm
Effective mass (as seen by stylus): 4.50 gram nominal+variable
Audio output lead length: 4'6" (137 cm)
Audio output lead capacitance: 112 pF (with phono plugs)
Tracking force: 0 - 3.5 grams
Pivot: inverted hardened steel pin pivoting on jewelled bearing damped by silicone fluid
Pivot friction: Less than 5 Mgm. in any plane measured at the headshell
Mayware Ltd. 15 Heather Walk, Edgware, Middlesex HA8 9TS England
Cheers
Pete
GRollins
Pete,
I'm not familiar with the arm itself, but in general it's a good idea to use as compliant a cartridge as possible with a unipivot arm. That would tend to push you towards moving magnet cartridges, since most moving coils are comparatively stiff.
Perhaps some of the Grados? Over the years, Joe has produced cartridges of varying compliance, but nearly always of good sound quality. There is usually a wide range of pricing, as well, depending on how much you want to spend.
Grey
peted
Hi ya Grey - and I thought when I saw the email notification you were gonna say you'd been using one for the last 20 yrs!!! OK, Grado Prestige Gold goes on the list to audition - there's some good reviews out there.
So hi compliance is at least what sort of number - any offers? Can you explain why a unipivot needs a hi comp (i.e. floppy) stylus? I can only imagine it could be because the arm is pretty lightly built???
The JH I referred to in initial post is JH Reproducers - who made a clone of the Mayware and is what I believe I have. I'll try put some pics on my web space (hesitate to call it a site) - http://users.computerweekly.net/peted/
Any other opinions out there please....
Cheers
Pete
[Edited by peted on 07-28-2001 at 04:49 PM]
GRollins
Pete,
Yeah, basically it boils down to two things:
1) Low mass arms (regardless of what sort of bearings they use) always need high compliance cartridges so as to keep the cartridge/arm resonance down in the subsonic region. I don't remember ever running across a high mass unipivot arm; surely at least in part because it would cause undue wear on the bearing. (The old woman in high heel shoes exerting more psi than a truck conundrum...)
2) Some unipiviots--whether yours is one or not, I don't know--are free to roll, i.e. the pivot pin comes up underneath a cone, which leaves the arm able to bob from side to side. This changes the geometry of how the stylus contacts the groove as the record is playing. Magnepan (yes, the speaker people) used to market an arm of this sort years ago. Higher compliance cartridges are more polite about not exciting this sort of motion.
Depending on what decade we're in, the Shure cartridges may or may not be another possibility for you, as they're generally pretty compliant, too. Sometimes they review well, sometimes not. I haven't heard any model of Shure in years, so I have no opinion.
Grey
peted
OK Grey, thanks for that. Looks like I need an arms for beginners book to get some background and a few auditions.
Oh yeah, forgot to put in the original post - the cart this arm was running with is a Sleeping Beauty (from Great american Sounds - GAS - James Bongiornio) - said by Allen Wright to be pretty much the same as a Denon 103 - compliance 5 x 10-6cm/dyne (100Hz) - that seems LOW - getting conflicting messages here - but then rules are made to be broken....
Me'be I'll shoot the question at Allen Wright again too.
Cheers
Pete
GRollins
Pete,
It's not that the 'wrong' cartridge won't work in a given arm...it will, in just the same sense that a tube amp will drive a subwoofer, and a $6 chip amplifier will drive a $150,000 speaker system. It's more a question of relative performance. Mounting a stiff cartridge on a low mass arm will produce music, but neither will be happy. It's like a terrier worrying at a sock...the cartridge will be shaking the arm (literally), when the ideal case would be to hold the cartridge absolutely rock solid, with the cantilever being the only portion allowed to move.
Obviously, in the real world, the cartridge needs to be allowed to move so as to traverse the surface of the album. It then becomes a question of compromises. How still can you hold the cartridge relative to the groove?
Might as well throw in LOI while I'm at it...
Back twenty-five or thirty years ago there was a table called the AR. It achieved a reputation for 'sounding better' than other tables, although its specs were pretty ordinary. (Yep, the same old story.) A fellow named Ivor Tiefenbrun (I may have misspelled his last name) took a look at the AR and decided he could do the same thing, but more so. Thus was the venerable Linn Sondek born. It was a shock and revelation to those who thought that all a turntable had to do was have constant speed and low rumble. Ivor, however, wasn't just blowing smoke--he really did know why the AR sounded better (and his own Linn Sondek better still). He called it Loss Of Information Theory. The basic concept is simple. The finer details of music encoded in the grooves of a record are on the order of wavelengths of light. Sloppy bearing tolerances--well into the thousandths of inches--were allowing the sundry mechanical parts to move around sufficiently to lose the details. His solution was simple. Tighten up bearing tolerances for the main spindle bearing for the turntable (the Linn LP-12). The pivot bearings for the arm came later (the Linn Ittok arm). And all the various mechanical connections in between, including the mounting of the arm board to the sub-chassis, the arm to the arm board, etc. The result? Better everything. More, tighter bass. Solid image with more depth and width. More extended and accurate highs. The works. Other manufacturers improved things even further, but Ivor was the one who figured it all out. Thanks, Ivor. And yes, I still have my old LP-12 as a backup turntable after all these years.
Depending on how much of a masochist you are, other possible topics include: cartridge alignment, stylus pressure, overhang, tangential vs. pivotted arms, turntable suspension, mass loading of arms, arm resonance, direct vs. belt drive and VTA/SRA.
If any of that sounds interesting, let out a holler, elseways, I'm gonna take a nap...
Grey
dice45
quote:
Originally posted by peted
... So I need ideas for suitable cartridges please folks. Denon 304 and the 103 have been suggested. 103 difficult to obtain apparently now. I have a number of proven tweaks also for this arm. Am intending to fit to some as yet undefined self built deck - perhaps an Origin Live kit.
Hello Pete,
if you want to get MC experiences with your unipivot, you might ask John Elison on the Vinyl Asylum (he is a very helpful guy), he runs a Denon 304 (or was it 305, dunno) in an SME 3009 Series III which has an effective mass of about 3 to 4 grams. The Denon he has is definitely high-compliant and well-mated for his sort of effective mass. Quite opposite to the Denon 103 which has a compliance in close proximity to that of a screw driver. I fully agree with Grey's warnings.
However, a unipivot arm mating well with a DL 103 is not impossible, a buddy built a unipivot 12"er for his Denon and the combination seems to work fine. The arm has high rotational inertia with reference to the tonearm wand, this is why it works.
Tell me more about your self-built turntable, has the project developed already?
sandro
I do have a Mayware mkV (almost identical to IV) and use a Denon 305 and a Stanton 881S.
Both are working ok, although the marriage is not optimal: the 305 sounds better than 881 but her compliance is 'close to the limit' for the mkV.
I agree that a Grado could be the best choice (at least is my intention to try a Grado Signature as soon as my budget plan comes to the 'pick up' chapter).
Documentation for the arm is very poor, just 2 pages, also it seems that Mayware does not exist anymore, so it is very difficult to have informations on this arm. (any hint is welcome!)
BTW, in the 90 Mayware itself was trading pick-up designed for their arms, and reports are they had a damn good quality/price ratio. Maybe is possible to find a 'new old stock' somewhere.
bye
sandro
planet10
Hi all,
In my hifi store days i sold MANY of the UK version. We put them on ARs, ERAs, Thorens TD160/165/125, Linns, Connosoiurs.
I have one of them came back to me recently (on a TD165) with almost all the set screws loose and the arm majorly ascew. I'll get to putting it all together sometime soon. (and a friend i haven't seen in years who dropped in last week is sending me another).
90% of the time these went out the door with a Grado. They don't work too well with a Denon. Most often if we were selling a higher cost MC cart we would also sell a better arm.
I'd be interested in the mods you mention. A couple standard ones are gluingthe arm where only set-screws hold things together, heatshrinking the arm tube (and losing the sliding weight for setting tracking weight).
BTW Olive Oil works fine as a damping fluid -- and is a whole lot easier to clean up.
dave
PassFan
There are a couple of Brand new Grado Golds on Ebay under turntables for 105.00
dice45
quote:
Originally posted by sandro
I do have a Mayware mkV (almost identical to IV) ...
Sandro,
i have no data about the Mayware arm, but if you post one or two pixes of this arm and tell me the data from your technical spec, i might come up with some neat hints how to set it up and to mod it to better low end performance.
After all, we will have to struggle to fill the TT forum to come with life :)
sandro
Hi Bernhardt,
I have no scanner &/or other digital imaging stuff (I'm an analogic residuate...), the arm is very similar to the F4 version, you can see Peted's pics. Will post the specs as soon I have time to copy the sheet.
Thank you for your offer, anyway
bye
sandro
dice45
Hello Sandro and all Mayware users,
looked at the pixes meanwhile and found my supicion proved.
The tonearm almost certainly has not enough rotational intertia.
A very common disease among unipivot tonearms.
Without damping, the torque exerted by the stylus on the tonearm's rotational inertia (imagine it as as rotational "effective mass") triggers rotational oscillations of low freqency, but not low enough. With damping, the arm is coupled to its pivot base, the coupling increases with the frequency going up. Of course, there is considerrable damping already at the resonant frequency and the amplitude peak of the oscillation is low. But as it is the case with all mechanical dampings, the more damping we have, the lower the Q factor and the less steep the resonance decoupling curve, the transfer function, is falling.
Which means: a low rotational inertia and considerable damping together do not make the arm near as stiff in the range of 20 to 80Hz as if the rotiational inertia would be sufficiently high and no damping is applied. Because in the latter case, the Q factor is very high, the resonant freqency is low enough (say, 1 Hz) not to disturb the audible range. In reference to the excitation, the transfer function of this oscillating system, its "output" goes from unity (below resonant freq.) to a peak way higher than unity (@ resonant frequency) and with further increasing frequency of the excitation, it drops to waaaayyy less than unity, so fast that at 20Hz (more than 4 octaves higher) it has already reached -60dB or more.
Which means in short: the arm being ultra-soft against rotational excitation at 1Hz is very stiff against them already at 20 Hz and few audio systems make it to that basement. It is superstiff at 50Hz.
Another important fact: any mass added to the arm affects the arm's effective mass in proportion to the square of it's distance to the arm's center of inertia.
As a practical result, i would carry my unipivot arm (id i 'd own one) to a mechanic wizard and tell him to mount two small rods exactly at the height of the pivot point and in rectangular orientation to the tonearm wand, or better, rectangular to the headshell's offset angle. On these rods i would mount slender, lengthy weights then to achieve a rotational resonace frequency as low as possible.
[disgressing, <tonearm resonances>]:
remember i used slender weights, the arm's effective mass in vertical direction is increased only by a tiny amount as the the slender weights have almost distance zero in reference to the arm's pivot axis of up-and-down movement. Effective mass in lateral direction is increased more and thus vertical and lateral tonearm resonant frequencies are pulled apart for which i am very grateful as a lowered lateral resonance improves tracking. Many folks believe tonearm resonance has to be between 8 and 12 Hz. I agree for the vertical resonance, a resonance too low makes the stylus jump grooves and, too high, it muddens the bass. But think a bit which triggers lateral resonance: disc excentricity (0.55 Hz at 33rpm, up to 2.5mm amplitude) and groove feed (< 1Hz, 50µm amplitude). Methinks that a lateral tonearm resonace as low as possible but above 3Hz is ok. Airborne linear tracking tonearms, particular the DIY Ladegaard arm would not work if this opinion would be dead wrong, Poul Ladegaard thought the same and proved it by his arm.
[/disgressing]
The weights should be equal and adjustable in distance to the pivot: Eeezy azimuth adjustment with high resolution is the payback :) .
I would have a mechically skilled person do the modification, the arm looks soo neat :)
Who got lost in my description (nobody i hope :( .. :) ) and/or wants further proof: please track the web for Stax tonearms. Some of them have such side-weights and they work extremely well, are considered to be the best unipivots by some.
A buddy bult himself a unipivot with high rotational inertia and high effective mass too: he wanted to make his Denon DL103 track 1st class and he succeeded. He had the side-weights not at the pivot but agreed this would be better and said this would be the next development step.
Consider, the Denon has a compiance of only 5 µm/mN . A challenge for any tonearm, not only for a unipivot.
All for now, if questions arise, pester me :)
dice45
As noone replies,
do i feel right assuming my explanations were too scientific?
peted
Hi Bernard,
many thanks for the info here - as thread starter I must apologise for not monitoring it more - lack of time I'm afraid. No - the science is good - keep it coming...
I have updated my site at http://users.computerweekly.net/peted/arm.htm as follows:
1) Two new pics of my own arm - 95% sure this is a JH Labs Reproducers version of the Mayware (hopefully the new pics will clinch it.)
2) Details of some tweaks I have obtained. I am not in contact with or know who the arthor was, nor have I tried these tweaks myself - take them for what they are worth, but they appear to be aimed at stiffening and damping.
Also there is an orginal Mayware manual for the Mk4.
My arm is very light - the headshell appears very flimsy - common sense might suggest it's all too flimsy - but then perhaps not at audio freq - and we all know the appicane of science (even common sense!) is often dangerous in this game...
Hope this helps
Pete
jbateman
I used to own one one of those, although I could swear it was manufactured in Japan. FWIW I used a Shure V15 type IV...very high compliance, with good results. But I never liked the way it rocked from side to side as it encountered warps.
dice45
Thanxalot for the +FB :)
Went thru your site. The author of your mods obvioulsy had tried them all out and knows what he is talking about. I would have recommended just the same from experiences with other tonearms. I'd suggest you consider it as you Mayware mod bible ald follow thru all the
mods, any single of them. Maybe you add my rotational inertia increasing mod tothis list and together with that, apply as few silicone oil damping as you can live with.
Use single strand silver wire. Try the 75µm wire from
http://www.a-msystems.com/physiolog...silverwire.asp. So will i, currently i use 100µm enamelled copper wire in my SME V.
Have to agree. Headshell is flimsy. I have a headshell mod but hesitate to post it as it is a permanent mod like the cartridge glueing but may work out different with different arms. I would assist with advice (offlist) but you have to do it at your own risk.
Consider, the original Decca unipivot arm used a thin and soft piece of bent sheet metal as headshell -- and sings like hell with it. So flimsy headshells can work (must be errors compensating errors : ) ). But as your mod author recommends heavy headshell damping, i would presume that building a new headshell around the Mayware's original one (using 0.5mm thick FP4 PCB material spaced by µ-balloon-filled epoxy) has nothing but advantages.
Email me if you are bold enough to try it :)
planet10
100% sure. I have attached a picture of my sad mayware F4.
I have tried most of the tweaks mentioned (my earlier post covered off what is considered standard mods) and they do work, enhancing rigidity & reducing sources of resonance.
dave
GlennME
Ah, good old JH. Back in the late 60's to late 70s JH manufactured the cheapest turntable available to Australian Hi Fi owners. They practically had a monopoly on locally manufactured turntables, and the JH was dirt cheap at around $40.
$40 got you a wooden base about eighteen inches by fifteen inches by five inches, with absolutely no suspension. The belt drive turntable was screwed directly to this wooden base. The turntable was powered by a small clock motor with a round belt about 1/8" in diameter, with a nasty join in it. The rotation of the turntable was easily stopped by simply touching it with one finger.
Like so many Australians buying a Hi-Fi system at the time, I started out with one of these turntables. Back then I was an apprentice electrician, and my first hi-fi system consisted of a JH turntable, a Sansui amplifier and a pair of headphones. I couldn't afford speakers until about six months later. I bought the turntable second hand and it had a tonearm already mounted on it.
JH had this single product to their name; a bare minimum turntable at the bottom of the belt drive heap.
Around 1975 JH introduced a second product; the JH unipivot arm. It too sold for $40, and unlike its stable mate, the hi-fi press raved about this simple but effective tonearm. I bought one, and added it to my trusty JH turntable.
The tonearm was terrific, and found itself mounted on a couple of different turntables over the next few years, until that fateful day it was smashed when I moved house in 1980.
By that time JH industries was no more. Some time in the mid 70s they stopped producing the turntable, and a little after that, the tonearm disappeared. JH faded away and have never been heard of since.
I can confirm from your pictures that the tonearm is identical to the one I owned.
tvi
<i><font color=#800000>Who got lost in my description (nobody i hope .. ) and/or wants further proof: please track the web for Stax tonearms. Some of them have such side- weights and they work extremely well, are considered to be the best unipivots by some.</font> </i>
Like this from the "<a href="http://isweb4.infoseek.co.jp/art/exp4/">STAX Unofficial Page</a>"
<a href="http://www.hoops.ne.jp/~asd123asd/ua90.htm"><img src="http://www.hoops.ne.jp/~asd123asd/ua90n-2.jpg" ></a>
For a moment I thought you ment something like the <a href="http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=/netahtml/srchnum.htm&r=1&f=G&l=50&s1='4352178'.WKU.&OS=PN/4352178&RS=PN/4352178">Cartridge equalizer US Patent 4,352,178</a> see attached pic below.
<hr width="95%" align=center>
With regard to peted/images/arm_mods.htm
<i>Movtite?</i>, I think this should read <a href="http://www.efi.org/products/weather/mortite.html">MORTITE</a> Rope Caulk?
James
dice45
James,
quote:
Originally posted by tvi
Like this from the STAX Unofficial Page ..
Rrright. :)
quote:
For a moment I thought you ment something like the Cartridge equalizer US Patent 4,352,178 ...
i do not know what this is and if i muse about it .... i do not want to know :)
Cartridge orgasm exciter maybe !?
BrianL
I have a Mayware Formula IV, though it is in hibernation. It met with an unfortunate accident which resulted in its pivot "nail" being sheared off. Here are a few things I did with mine:
1. reinforced the headshell per an article in Audio Amateur. Mainly this involved epoxying little triangular reinforcements at the bend in the headshell piece and trimming away needless headshell material.
2. firmly attach headshell to the arm tube with LocTite
3. One can somewhat tune the resonant frequency of the arm by using the sliding stylus-force-setting weight and thus changing the arm effective mass and thus its resonant frequency. This requires careful adjustment of the main counterweight to set tracking force. For my Shure V15-V I slid the sliding weight all the way toward the pivot. Some people actually removed it.
4. I replaced the arm wiring with four stands of fine Litz wire (5x44 ?)
I never had problems with tortional motions though it was a pain to get the eccentricity of the counterweight just right to get the 'pitch' of the cartridge just right.
Soncially the arm was good for its day and may still be quite good. However it's been so long since I've used it and the rest of my system has changed so much since then that I really can't make any value judgments.
Speaking of tonearms, does anyone have experience with the Technics EPA-500 arm?
dice45
Brian,
concerning the Technics arm ia m not sure they once had a unipivot arm with 500 in its model # so i presume this was the arm youinquire about.
It didn't have a good rep, maybe you consieder to get your Mayware out of hibernation and replace the pivot nail.
A good idea would be to buy a tungsten-carbide-tipped scribing iron and salvage the tip.
tvi
The <a href="http://mark.kouts.home.mindspring.com/technics.htm">Vintage Technics Website</a> has a pic of the arm
<a href="http://mark.kouts.home.mindspring.com/sl1015.html"><img src="http://mark.kouts.home.mindspring.com/images/sl1015catalog.jpg"></a>
Is that it?
James
BrianL
Yes, James, that's the arm. I actually have one of those and 1.75 arm wands (one has a broken headshell). It seems a magnfiicent arm, and seems to have a cult following, probably because it is not well known -- even Technics/Panasonics does not know that they ever sold it. It is NOT unipivot but had, I believe, jeweled bearings with the lowest friction ever.
Anyhow, when I finally get around to building my Teres "kit" one or both of these arms will be "enlivened" to facilitate LP playing, though the Ladegaard looks very interesting as well.
(of course, I don't even seem to find time to get anything working so who knows when this will happen :mad: )
If anyone is interested I could go into detail on the unique features of the Technics arm, but then this was supposed to be a Mayware Formula IV thread...
BrianL
Oh, and I should mention that the arm on the Technics "Disco Turntable) 1200 or 1210 (?) looks similar to the EPA-500 physically but doesn't seem to be anywhere near the quality, nor does it have the unique features.
jesserparker
if you're trying to resurect that arm i have a suggestion for the pivot. carlo morisani (read a review of his tonearm at TNT audio) claims the best sounding "needle" for a unipivot is what he uses in his arms: a gramaphone needle. these are really really cheap and easy to find (if you can't find some i have a link somewhere aroudn here i'll try and dig up for you if you want it), i'd be interested to see how they sound and the very idea of it appeals to me.
later,
jesse
EC8010
Dice 45,
you were disappointed that nobody replied to your post about rotational inertia...
Most unipivots are very badly designed. (Nothing like an uncontentious statement to begin a post.) They place their pivot way above record height. Play an eccentric record, or simply one that uses varigroove, and the arm moves from side to side. If the bearing is above record height, this side to side force twists the arm just like a pendulum.
On the other hand, if the bearing is at record height and centre of gravity is just below record height we don't excite twisting.
I don't agree with increasing rotational inertia. Increasing rotational inertia lowers the frequency of the pendulum. We damp the pendulum's motion with viscous fluid. It takes Q cycles to set up or damp a resonance, so a low frequency pendulum oscillates for longer.
Most unipivots apply their damping badly. We need lots of damping for the rotational pendulum, a little for vertical motion, and rather more for rotational motion.
This is not armchair theorising. I built my (high-mass) unipivot to these principles and it's very resistant (for a unipivot) to rocking whilst tracking a moving coil cartridge. (It's at the "Unipivot pick-up arm" thread.)
Peted
The Mayware is quite a flimsy arm, and at the time it was made people tended to use high compliance Shures or the Entre moving coil. I would be inclined to stick with highish compliance cartridges.
Nat Eddy
Just to wade in on JH, despite late date: That is clearly a JH formula IV. Maywares did not have the vertical pin at the back of the arm, whose function I assume is to trap the counterweight. Why this is desireable I don't know. None of the JH's I have seen had the sliding tracking force/mass adjustment weight that all or most of the Maywares had. The JH I have has a very flimsy plastic cartridge carrier, and does not have adjustment slots for overhang, so you need an adjustable base a la SME or an alternative. As far as I knowMaywares had metal cartridge carriers with adjustment slots. The Maywares were noticeably better made than the JH I have. I had an original Mayware years ago, which was built in Japan, and was very nicely done for the price.
I also had a JH turntable once. While it must have been an improved model -- it did have a suspension, if you can call three leaf springs a suspension (and why not? B&O did), but it really was as bad as the previous writer mentioned. I think a stamped steel platter, not even close to dynamically balanced. And the belt was still simply a glued rubber strand. I bought it at Q Audio in Cambrige to get the platter mat they sold on it (I think to give it enough mass to minimise somewhat wow and flutter. I am not sure why Q bothered -- most of the stuff they sold was high quality, but this was not. On the other hand, I think it cost me $25, so it may have been an evaluation piece.
Audio was more fun then...
Doesn't the Graham arm have lateral weights at the pivot point (and aren't they perpendicular to the cartridge in order to minimise yaw when tracking warps). This seems a good idea, but it requires more parts than the eccentric counterweight that the Formula IVs have -- and look at the price difference!
SY
The Vintage Technics link didn't work.
I'd give some valuable body parts to be able to get replacement styli for my old Technics cartridge. And those arms... wow. Beautiful stuff.
peted
Brilliant! This thread is still running almost 2 years later! I haven't looked in for a while or subscribed - loads of good stuff come in here - many thanks to all. Time to update my site... (and obviously get the thing back into service which would be really cool - there's just sooooo much of that round flat black stuff out there).
Cheers
Pete
ddarch44
Am modifying an AR XA TT with a Mayware Formula 4. To do so, I need a second nut that goes over the large threaded that attaches the arm to the AR T-bar suspension. Have had no luck finding this M20x100 (thread) bolt. Anyone who has mounted a Mayware possibly have this bolt as a spare? Willing to sell or trade?
Dave
Alasdair Beal
Sorry this is a late arrival at the discussion. I have used Maywares (Mk III and V) for a long time and they are very good. They are actually compatible with a wide range of cartridges because the playing weight adjustment system automatically gives variable effective mass - higher for low compliance/high playing weights and lower for high compliance/lower playing weight. Also, for a very low compliance cartridge, you can position the rider weight right behind the headshell to give maximum effective mass (adjust playing weight using the counterweight).
Points to note:
at the base of the arm pillar there is a locking screw which can be done and undone to adjust the height. However there is also a small grub screw and once the arm height is correctly set, it is important to also tighten this little grub screw, so that the arm is firmly held in '3 point contact'. Don't tighten any screws too tightly, because the arm is aluminium and you can strip the threads.
The MkIII has a thin spring steel finger lift which is handy but colours the sound. For best sound it should be removed. However the MkIV and MkV have cast alumium finger lifts which are fine.
I can confirm that the Mayware moving coil cartridges are excellent. I use the MC7V High Ouptut, which feeds my amplifier phono stage directly. However Mayware also made excellent step up transformers for their low output MCs.
I have a spare MC7VIII High Output cartridge, if anyone is interested in making a sensible offer for it.
Alasdair Beal
I notice that a previous correspondent sounded off about unipivots having rocking problems and the Mayware being flimsy. This sounds like standard generalisations about unipivots rather than specific knowledge of the Mayware, which was very carefully designed. The counterweight is a large diameter flat disc (to give high rotational inertia) and this combined with the efficient pivot damping gives rock-steady tracking. As for flimsy? Well some unipivots were (and the early Maywares may have been - I don't know) but the Mark III was perfectly solid, despite very low effective mass (with cast aluminium headshell) and capable of doing credit to a wide range of catridges. The MkIV and MkV have larger diameter arm tubes and more substantial bearing housings and are even better.
The fact is the Mayware is a very effective, clean sounding, versatile arm, with no real minus points and seems to have had a 'better sorted' design than most other unipivots. The MkIV and MkV are best but the MkIII is pretty good. One of the best features of a good unipivot is that there is really nothing to go wrong with it - the bearing cannot seize up, work loose, get stiff or rattle. In theory a well lubricated jewelled unipivot like the Mayware could almost go on for ever!
Alasdair Beal
SY
I do wonder, though, why the Mayware Formula IV I used for so many years never seemed to be a great match for Grado MMs, but did beautifully well with Shure V15s and with various Technics cartridges.
Bill Way
Actually an arm with quite a lot of potential. I always enjoyed the music with them. My suggestions:
cartridge - stick with high-compliance stuff, like any of the Grados. If you have the budget, the MusicMaker might be wonderful with it.
arm - I epoxied all the joints, rather than rely on the teensy set-screws. Crazy glue is great for this. I also put Cardas wire in, which is always a good move.
If you need help setting it up, email me. It takes about a half hour, but there's nothing difficult about it.
BTW, I once mounted one on an AR turntable, and the results were astonishingly good. I differ with those who say that unipivots and suspended turntables are a problem.
Alasdair Beal
Dear Billy,
What bits of your Mayware have you glued together? Assuming you still want to be able to adjust tracking weight and arm height, the only bit I can think of is the headshell.
On the question of compatible cartridges, you are wrong to assume that the Formula IV arm is only compatible with high compliance moving magnets. Because the arm is a low mass unipivot, people often assume this but they are wrong.
Because it is reasonably rigid and its tracking weight system gives it variable effective mass, The Formula IV is actually perfectly compatible with low compliance cartridges. I use a moving coil with a tracking weight of 1.8g and a compliance of 10 compliance units in the final version of the arm (the Formula V) and it works beautifully. How did I know it would work? Well, I looked at the name on the front of it: it is a Mayware (a lovely MC7VIII high output model with ruler-flat response, excellent tracking and a nude Vital stylus). Mayware's cartridges were always low compliance moving coils, so of course they made sure that their own arm was compatible with them. The idea that unipivot arms are only compatible with compliant moving magnet cartridges is a myth.
Happy listening!
Alasdair
Alasdair Beal
Oops, I made a mistake - although the brochure for the MC7VIII gave its compliance as 10mm/N, the instruction sheet with the cartridge gives it as 25mm/N, which I think is more likely to be correct, so this cartridge has actually quite a high compliance.
However the cartridge Mayware sold in the heyday of the popular MkIII arm, the MC2C, was definitely low compliance. I remember the MkIII instructions recommended sliding the sliding weight for adjusting tracking force right up behind the headshell when using low compliance moving coils. This increases the effective mass of the arm from about 5g to about 12g.
Alasdair
Alasdair Beal
PPS I recently bought a Denon DL-103 cartridge (definitely a low compliance cartridge) and mounted it in my Mayware Formula V arm. I moved the cursor weight to just behind the headshell, as recommended by Mayware and the sound is absolutely excellent -splendid basis, rock solid stereo and clean midrange and treble. So yes, i can now say for definite that the Mayware does work with low compliance cartridges. (I have it mounted on a Walker CJ61 suspended subchassis turntable.)
The Denon is as good as people say it is - quite remarkable given that the design dates from 1963. However you do have to be careful to give it the correct electrical loading: it needs to see 1 k ohm or less. With a higher loading (e.g. a 47k input with a 1:10 stepup transformer gives 4.7k) it sounds a bit brash.
AudioOrigami
http://www.audioorigami.co.uk/GoldM...GoldMayware.htm
planet10
quote:
I put quite a few of these on Linns, ARs & Thorens TD160s. They worked well. The unipivot NAIM ARO was built specifically for the Linn so NAIM obviously didn't think a suspended table was bad with a unipivot.
dave
EC8010
quote:
Actually, a 1:10 transformer will make a cartridge see 47k as 470 Ohms (impedance goes by the square of the ratio).
I notice that nobody has mentioned the excellent bias compensation scheme on the Mayware. It's so good, so elegant, that I copied it...
SY
Thread, pulley, and weight, if memory serves?
EC8010
quote:
Indeed, but the cunning bit was that instead of the thread being tied to a resonant outrigger arm (like the contemporaneous SME) it wraps round the pivot housing and uses it as a pulley.
Alasdair Beal
Oops, you are quite correct about electrical loadings for the Denon DL-103: I should have said that it sounds much better into 100 ohms than into 470 ohms.
Alasdair
Page generated in 0.14280104637146 seconds with 17 queries,
spending 0.00846982 doing MySQL queries and 0.13433123 doing PHP things.
Copyright ©1999-2009 diyAudio.com
